Go to Post This isn't just a robot competition, it's not robots driving robots. It's people driving robots, and teams of people who have put a lot into making the robots work. - Gadget470 [more]
Unread 17-02-2006, 07:22
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Gyro Calibration
Instructions contained within gyro.h gave a procedure for adjusting the GYRO_CAL_FACTOR from the default value of 1 (1000/1000) to a value that more accurately reflects the characteristics of your gyro.
Two things:
  1. I accidentally spun the gyro toward -1800 instead of +1800. I thought this would not make a difference if the percent error is still the same but apparently is does. What should GYRO_CAL_FACTOR be if instead of receiving -1800 as the actual value I got -1864? If you look at the code the math behind seems to make a GYRO_CAL_FACTOR of 1036/1000 detrimental to accuracy.
  2. How often do I need to repeat this procedure? Once every week or so? The instrument used to spin the gyro exactly a certain number of degrees weighs about 90 pounds and doesn't stay within easy access of the school. This also means I will not be able to repeat the calibration unless we bring this hunk of metal to the regional competition.
Thanks in advance,
Robinson
[Quick Secondary Question (sorry): does setting a digital output high mean setting it to 254, 255, or 1?]
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyro Calibration ImmortalAres Programming 1 07-06-2005 13:29
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Calibration roboticsjenkins Programming 11 21-02-2005 20:39
