Go to Post hmm..."give the gift of ChiefDelphi"? "This holiday season, send some Pontiac cheer to someone you love"? "Don't forget to put The Chief under your tree!" The possibilities are endless. - Jessica Boucher [more]
Unread 18-02-2006, 18:54
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Exclamation PLEASE HELP: OI switch box not working
Hi,
We have a switch box for our OI this year, and whenever one of the switches is pressed, the voltage drops and so changes the analog inputs.
We have the switches going from signal to ground. When nothing is pressed, there are 4.9 volts on the supply, but when we press something it drops to 4.7 volts.
So, we need a resistor (1k) on the switches, and it works fine. However, the buttons on the joystick do not have a resistor and they work fine.
And shoving a piece of wire to connect the pins as the switch would has the same voltage dropping problem.
Thanks so much for any help!
~Stephanie
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 18-02-2006, 19:22
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
Re: PLEASE HELP: OI switch box not working
How do you have your switches wired? Specifically, what are the two terminals on your switch connected to?
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 18-02-2006, 19:34
RbtGal1351's Avatar
AKA: Stephanie
FRC #1351 (TKO)
thanks but we just found the problem
one of our joysticks was drawing current for an unknown (as of now) reason. We're switching joysticks.
Thanks
SVR 07: 36th seed
What I'm Working On Jared Russell Programming 2 18-01-2006 02:34
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Digital Inputs interfering with each other Bongle Programming 8 23-02-2004 11:18
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
Modular Control box assembly Andrew Wyatt Technical Discussion 4 29-11-2001 15:44
