Go to Post Moral of the story: Crashes happen, things break... SHIFT HAPPENS. - Qbranch [more]
Unread 19-02-2006, 21:02
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
Ball Visibility
What exactly qualifies for "clearly visible", when it comes to balls at the beginning of the match. We have an opaque funnel-like mechanism, clearly visible from the front and top (in fact, open). However, beyond that, one or two balls might be underneath other balls, and thus not 'clearly visible'.
Is this valid as per G13, or are we going to have to scramble tomorrow to make plexi windows?
Unread 19-02-2006, 21:14
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Team Role: Leadership
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
Re: Ball Visibility
From one angle ALL the balls must be visible so the referee can count. I think you need to start cutting.
[EDIT] Wayne Doenges has it right, go by what he said .[/EDIT]
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 20-02-2006, 00:38
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Ball Visibility
If a ref can walk over to your robot and be able to count the balls quickly without having to bend over or move anything, you should be ok.
Wetzel
Viva Olancho!
Unread 20-02-2006, 02:59
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Ball Visibility
Here's the official from FIRST Q&A:
The referee will stand near (not sit, squat, lie prone, jump, hover, or float above) the robot while examining the robot to determine the contained ball count. Teams should not assume that the referess will go through any gyrations or assume special postures to enable them to determine the ball count. Note the Rule <G13> requires that contained balls "must be clearly visible from outside the ROBOT."
Hope it helps
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Ball Visibility (G13) dmlutz Rules/Strategy 3 20-01-2006 23:52
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
