Go to Post FIRST really does enjoy watching us squirm with their teasers, don't they? - Anupam Goli [more]
Unread 20-02-2006, 02:03
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Maximum PWM length
What is the maximum length you can run a PWM cable without loosing the signal? We are looking at running some sensors and servoss with cables maybe 3 or 5 feet in length, and I want to make sure the signal will make it.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 20-02-2006, 07:16
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Maximum PWM length
That should be no problem.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-02-2006, 07:27
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I agree with Al that you should be alright, but i swear i remember reading in something IFI wrote (i dont remember if it was in their forums or in a whitepaper or a datasheet or what) that they said that PWM wires should not be longer then 5 feet.
If i can find the exact document i will edit this and link it.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 13-03-2006, 23:06
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
The only issue with length should be signal interference. In 2002, we designed a remote "runner" mouse for our robot, and it had about 30 feet of cable running to it, with power for a motor, and a signal cable for a steering servo. With the long cables running right next to each other, the motor power cable would interfere badly with the steering of the servo, so we switched to shielded cable for the servo, and it worked fine.
Here's one of the photos of the runner.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 13-03-2006, 23:14
Thats pretty cool but I think I would be afraid to put something like that out on the field. Well ultimately I had no trouble with pwm length. Thanks all.
Unread 13-03-2006, 23:18
ECarlson's Avatar
AKA: Eric Carlson
It didn't make it out on the field much, but that was a year that lots of teams had runners.
- Eric
reading hobby PWM sciguy125 Programming 2 17-10-2005 20:47
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
maximum length of joystick cables archiver 2001 2 23-06-2002 23:54
