Go to Post The rules are the rules, but if the rules get so ridiculous some of us may choose not to play anymore and that is the bigger shame. - Paul Copioli [more]
Unread 20-02-2006, 13:32
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Wiring an LED from the OI
Recently, in the robot showcase section, a team showed off a "HUD" where they had three LEDs attached to his goggles. This made me ponder how to wire an LED from the OI that would light up if certain parameters are met (which I assume I would have to program.)
Any advice?
Unread 20-02-2006, 13:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Wiring an LED from the OI
Windward,
The OI has several outputs that are meant for direct connection to LEDs. We use them all the time for position, tally and calibration. See the OI manual for pinout and description.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-02-2006, 13:42
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
The pins that you can use for wiring up LEDs are enumerated in the reference guide for the Operator Interface. These pins correspond to the LEDs already visible on the OI, and thus are addressed the same way in code.
http://ifirobotics.com/docs/oi-ref-guide-11-21-05.pdf
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-02-2006, 13:57
Windward's Avatar
FRC #1452
Thank you very much for the links and quick reponses! Hopefully we'll test this out soon enough.
Unread 20-01-2007, 22:48
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Sorry to resurrect this, but it didn't really answer the question I have: how to do that physically and simply. We had a HUD on SPAM last year, but it went into a custom control box so it was just some additional wiring.
We currently are using joysticks into Ports 1-3 and a custom box into Port 4; that means we only have to wire up one custom harness, as the other three can just use the existing joystick connector. If I want to use the LED outputs in Port 1, do I need to make a Y cable leading to a 15 pin connector for the joystick and a smaller connector or wiring splitting off to the LED's? Is it possible to take apart the joystick and take it off there? (I haven't looked so I don't know if the cable carries all 15 leads) Is there a simpler way?
Also, do I just need to split off the LED pins and one ground pin?
Close enough to taste it, too far to reach it
Unread 20-01-2007, 23:25
karlcswanson's Avatar
karlcswanson karlcswanson is offline
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
A Y cable would probably be the best option, the hood on the joystick connector might be molded around the db15 connector, and all 15 pins might not be accessible inside the joystick. You would only need to split off the led pins and a ground pin.
Unread 21-01-2007, 13:54
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
FRC #0294 (Beach Cities Robotics)
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Well, I believe you might be referring to my team's (294) '06 robot. I can't actually tell you how it works because this is my first year on the team. But I can tell you that it wasn't very complex.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Running a LED on 6v? Chriszuma Electrical 23 15-03-2005 18:06
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
