motor failure
We have the andy mark transmission and we got the ones to run the big cim motors and the small ones. We wired everything up and found the two bigger ones were not working but then we got them working by switching out the speed controller on one and the pwm on the other. we walked away for a couple minutes and now it doesnt work again. Nothing got moved and nothing is unplugged but now three out of four motors are not working. Has anyone ever had a problem simialar to this one.
Re: motor failure
Re: motor failure
It is difficult to get the PWM cables to seat properly. When fully inserted, the brown shell should be exposed by no more than 1/8". Any more than that and the pins are not fully inserted. Otherwise invoke the Notke rule and go where the last person was working. All will become clear.
Re: motor failure
generally in engineering you look for a single point of failure. If three motors have stopped working then most likely one thing has failed that can stop all three motors
I would look at stuff like your ground connections (ground stud or the terminal block) or make sure your SW guys didnt decide to test new SW when you were not there. It very rare for two things to fail at the same time. Extreemly rare for three things to fail all at once. Look for the single link that ties them all together. |
Re: motor failure
Re: motor failure
Thank guys it was the pwms were not getting good connection i appreciate the help and advice.
