Go to Post As in life, the more restrictive the rules, the more creative the 'best' solution will be. - DonRotolo [more]
Unread 21-02-2006, 04:20
P1h3r1e3d13's Avatar
P1h3r1e3d13 P1h3r1e3d13 is offline
Unregistered User
FRC #0295
P1h3r1e3d13 is an unknown quantity at this point
Question Victor on fire
For what reasons have your Victor speed controllers failed?
After having run our RC and all motors on and off for some time today, we heard a loud SNAP! like an electric arc and we saw and smelled a small whiff of electrical magic smoke. We killed the power, checked everything for shorts, grounds, disconnections, etc. We found nothing and after bench testing the only suspect part (a Victor), we reassembled and tried again. This time we were greeted by large quantities of magic smoke, glowing red transistor heat sink and 2-inch orange flames from a different Victor, and killed the power again. Turns out that transistor was cracked. We replaced that speed controller with a spare, and same thing: more magic smoke. We're pretty sure its from the replacement Victor.
Any ideas?
FYI:
The controller is hooked up, like our other 3 drive motor controllers, via a PWM Y-cable (2 motors/side) and power is through a 40 amp fuse and to a small CIM motor which (along the other on that Y-cable) drives a default gearbox.
We double-checked everything at each step after the first problem and we're pretty sure, at least, of the following:
No other components failed: wires, fuses, cables, motors, etc.
The motors aren't working against each other (though this is still a slight possibility)
All controllers are Victor 884s with blue writing (this is certain).
Unread 21-02-2006, 07:24
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Victor on fire
On the list of Victor failures...
1. Metal shavings inside the device.
2. Driving a locked motor over a long period of time.
3. Two motors fighting each other in a multi-motor drive.
4. Short on the output or power wiring connected backwards. (A hint on this one and the two previous ones is a buzzing sound coming from the circuit breakers)
5. Metal shavings inside the device. (yes I repeated myself, but this is the cause for about 90% of failures.)
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-02-2006, 15:07
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Re: Victor on fire
Try replacing the PWM cable. Our team has had problems with the Y-cables before and they routinely stop working. I would go back to regular PWM cables. Also, make sure that you have sufficient cool air flow from your fans
Make sure that your PWM cables are properly oriented
Unread 21-02-2006, 21:25
Unregistered User
FRC #0295
Re: Victor on fire
Good call on that - a postmortem on the dead Victor revealed some small aluminum shavings. Our theory is that when we blew out the speed controllers with compressed air, we had the power and motor wires removed and we blew shavings into their screw holes. Inside those connectors is where we found the most shavings. We're still not sure about the second failure - we are in the process of removing, disassembling, inspecting, cleaning, reassembling, and remounting all of our Victors.
Thank you, Mr. Skierkiewicz, for being so helpful to us and everyone else here.
And coldabert, thanks, but before this problem, the Victors' LEDs tipped us off to a PWM cable problem, so we checked all the cables with our handy-dandy multimeter and as of the time of failure (and right after) they were all good.
Unread 21-02-2006, 21:35
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Victor on fire
With your replacement: According to IFI, if you wire the victor's power leads backwards, they will be destroyed. I don't know if this means fire and smoke, but could be the cause.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 21-02-2006, 22:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Victor on fire
Older (red-label) Victors would fry approximately instantly if given power backwards. The newer ones have reverse polarity protection, which apparently means that they will trip a circuit breaker in just a few moments after power is applied backwards.
Unread 21-02-2006, 23:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Victor on fire
FYI, we had a victor tripping a circuit breaker and couldn't figure it out. It turns out we'd lost a screw at some point and someone had replaced it with a longer one, thus shorting the output to ground.
Gear Tooth Sensor FIRE Aaron_H Electrical 5 17-02-2006 12:29
Chatsworth Fire in California, and other disasters. Dr.Bot General Forum 0 02-10-2005 12:38
Apple recalls batteries due to possible fire hazard Jay H 237 Chit-Chat 10 22-05-2005 12:20
Serious VCU Fire Joe Matt Chit-Chat 3 26-03-2004 19:04
