Need Some Ideas...
OK, so I have this final project for my class in school and I have some clue but I thought I'd let all my fellow FIRSTers weigh in on it. Here's the details:
I have to make a machine that will move a marble 10 inches in any direction, and then return it to its starting position. Rules: Can only touch the machine once to start it. Use a battery supply. Maximum of 2 feet by 2 feet. Place it on a level tabletop. Include motor/gears, relay, switch,conductors and Incorporate 2 Different simple machines in the machine; -Lever -Inclined Plane -Wedge -Gear -Pulley -Belt Drive or -Wheel and Axle -Cant touch the marble to start it If you have any ideas, suggestions/comments, reply at will. ![]() |
at least 10 inches or 10 inches exactly?
So basically this is a Rube Goldberg project?
I'd suggest having more of an objective that takes more thought. In our FIRST class we had to put toothpaste on a tooth brush using no power, just one dropped marble to start the project |
It's a minimum of 10 inches, its not really a FIRST class, trust me when we do those projects it takes a lot more though
Ok so make a see-saw type contraption, 10" long and when you start it the see saw will send the marble from one end to the other and then back all with one little motor.
what do you mean by
-Cant touch the marble to start it ?? |
To start the machine the marble cant be pushed or touched, has to be like a switch or something
So does that mean the natural movement of a see saw would not be acceptable?? Does something have to touch the marble to push it? Or can it just be inclined to roll???
I can touch anything except the marble, so i could just push the see saw down.
| Need help drawing my ideas | Keith Chester | Technical Discussion | 12 | 08-11-2003 20:09 |
| Help with mousetrap wheel ideas! | Ashley Weed | Technical Discussion | 12 | 13-10-2003 21:05 |
| New year, new ideas!! | Tyler Olds | 3D Animation and Competition | 3 | 08-10-2003 00:23 |
| Problems with rookie ideas?!? | Tton | General Forum | 7 | 08-01-2003 22:10 |
| tell us your ideas your not going to do | archiver | 2001 | 5 | 23-06-2002 22:35 |
