Go to Post Excited and motivated students and teachers can do amazing things. - Wetzel [more]
Unread 22-02-2006, 17:09
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Team Role: Leadership
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Re: Ramp Climbing Adventures
i think that the robots that can make it up the ramp will make it to the final of the regionals/championship. what teams can make it up the ramp? what do you have that enables your robot to do the ramp?
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 22-02-2006, 20:05
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Successful attention to stability, center of gravity, and driving skill.
Unread 22-02-2006, 20:36
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Can someone push us up?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 22-02-2006, 21:48
Nita's Avatar
Nita Nita is offline
^_^
FRC #1190 (Anonobots)
Nita is just really niceNita is just really niceNita is just really niceNita is just really niceNita is just really nice
We tried the ramp for the first time at the CO scrimmage and we fell on our side and took the side of the ramp with us. Oh yeah, our robot has to be driven backwards up the ramp because of our ball-collector.
Unread 23-02-2006, 16:55
AKA: Matt Starke
maybe i am wrong. i guess with 30 degrees and very little friction to grab onto i figured not many teams would me able to do the ramp. i also thought about how 6 wheel drive robots probably would not be able to do it easily because you would create a teeter-totter. am i wrong with my predictions?
Unread 23-02-2006, 17:30
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
We originally planned on going up the ramp, but for some reason our chassis ended up being wider than long. So, we tip either way...
Unread 23-02-2006, 18:18
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
we can go up and down the ramp and even score three's from the ramp! and like Greg said we really shake the alliance platform, one time we were accidentally in high gear and smashed our way up. you should have seen the look on the driver in the middle station . it was good enough for the news
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 23-02-2006, 19:50
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
we used the dimensions for width too. we can still climb. also down too. although we could use some suspension for that. dynamic brakes arent the best for that.
Unread 23-02-2006, 22:59
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Careful design helps. We made sure that the weight was low and far enough back that we don't tip onto the top of the ramp until the middle wheels have gone over the edge. It works nicely for us
Unread 23-02-2006, 20:04
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Ditto..
A low center of gravity and alot of driving skills along with how fast you go up the ramp...
-Pavan
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 24-02-2006, 11:28
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Team Role: Teacher
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
The first time we tried to climb the ramp, our robot flew up the ramp, crashed THROUGH the rear wall on the ramp, and smashed into the back wall of our shop.
We spent the next thirty minutes picking all of the pieces.
Unread 26-02-2006, 03:34
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
Our robot can go up the ramp forwards and backwards. Its the coming off that's hard!
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 26-02-2006, 16:32
TheOtherTaylor TheOtherTaylor is offline
In case you already know a Taylor
AKA: Taylor Weiss
FRC #1868 (Space Cookies)
TheOtherTaylor is a jewel in the roughTheOtherTaylor is a jewel in the roughTheOtherTaylor is a jewel in the roughTheOtherTaylor is a jewel in the rough
Send a message via AIM to TheOtherTaylor
Testing driving up the ramp was quite an adventure. Without modifying the bot at all we tried going up at various speeds.
Going up we wound up with half the bot sticking up in the air while the back of it was still on the ramp, then all the sudden the front would come slamming down making quite a racket but not damaging the bot in any way (not any way we noticed at least)
We couldn't come back down at all (discounting one time in which my timing was perfect but I wasn't able to repeat it) for a while until we took every little bit of spare weight available and strapped metal blocks into the front of the bot. Coming down is noisy and looks ugly as heck, but it works now.
If I can find any pictures or video I'll put them up.
The Other Taylor now back in the bay area with team 1868 as a mentor.
-Team 2420 Mentor (2008-2010)
-Team 1002 Mentor (2007)
-Team 1351 Designer, Machinist, Driver (2004-2006)
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. Douglas Adams
Unread 22-02-2006, 20:09
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
I've written this before on this forum... at the Bellevue pre-ship event, all of the robots at the event were 6WD and all could climb the ramp (although with one of the rookie 'bots it was kind of touch and go there for a while.) The six veterans could all easily climb the ramp, and the four best chassis could pretty much do it up or down, straight or diagonally. So, I'm trying to figure out what's so hard about it? (I do confess that fanatic attention to CG seems to be a PNW trait. Over the last two seasons I've seen pics of bots from other parts of the country that looked really tippy.) Wooden Thunder and Top Gun are pretty primitive compared to some of the big-bux teams, but they don't tip easily...
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
  #15   Spotlight this post!
Unread 22-02-2006, 20:21
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Megamaid can now get up the ramp after a quick adjustment. We have to drive backwards, though, as we only have 2 drive wheels (plus two omniwheels in back). Coming back down is the hard part.
pic: Team 39 robot climbing ramp Ken Loyd Robot Showcase 9 20-03-2006 04:05
Ramp and Tipping Nitroxextreme Rules/Strategy 10 10-02-2006 15:01
Ramp Scoring, At 00:00 or After? Rombus Rules/Strategy 21 05-02-2006 17:02
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
pic: Project X climbing up the side of the ramp CD47-Bot Robot Showcase 2 25-02-2004 23:24
