Go to Post If I had come up with a chokehold strategy, I wouldn't talk about it on Chief Delphi. - Tom Bottiglieri [more]
View Poll Results: do the side goal proximity rules affect your robot
yes 1 3.70%
no 17 62.96%
only if our driver messes up 1 3.70%
side goal proximity rules? 8 29.63%
Voters: 27. You may not vote on this poll
Unread 22-02-2006, 21:26
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
goal proximity rule
i know that a rule states that the robots that go for the side goal have to stay outside 3 inches from the side goals
however in the scrimmages so far teams have broken this rule numerous times.
does this fairly unknown rule affect your robot? ours has a door so it is important with ours.
EDIT: this is rule G21
Unread 22-02-2006, 21:33
gondorf's Avatar
Re: goal proximity rule
<G21>
ROBOT Incursion into the Corner Goal - Incidental incursion into the corner goal that occurs as a resultof a ROBOT pushing balls into the goal is permitted, not to exceed a distance of approximately 3 inches.
Intentional incursion, for example to use a ball gathering mechanism to drop off balls inside the goal, or extending a portion of the ROBOT through the goal opening to activate the ball counting system, will
result in disqualification of the offending ROBOT.
this is a bad thing for some teams. please post your opinions
Unread 22-02-2006, 21:44
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Team Role: Leadership
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
I am pretty sure you are a little confused in your interpretation. You can not go 3 inches THROUGH the goal, meaning that your robot can not extend through the opening more than 3in.
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 22-02-2006, 21:48
gondorf's Avatar
it says that for incidental occurence
having a door that the balls roll down is probably not considered incidental scince it is desined to go into that goal and drop the balls off to avoid the ramp
Unread 22-02-2006, 22:27
AKA: Erik Thulin
No, thats not what I am referring to.
You state: i know that a rule states that the robots that go for the side goal have to stay outside 3 inches from the side goals
When really the rule is the bot may not go through, as in on the corral side, the goal by 3 inches.
You get the difference?
Unread 22-02-2006, 22:29
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
<G21> says that incidental incursion may not exceed 3 inches into the side goals. It does not establish a 3 inch exclusion zone outside the goal. A robot inserting an active ball delivery mechanism into the goal will be disqualified, but dropping a door onto the top of the goal ramp to prevent gravity from working against you isn't against the rule.
Unread 22-02-2006, 22:34
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
R.T.M.F. Read The Manual First!
<G21> Has been there since kickoff. You can not incidently "enter" the goal any more then 3 inches. Though you should have designed the bot to not even enter the goal as there should be no need to do so.
-Michael Dessingue
Unread 22-02-2006, 23:36
AKA: Erik Thulin
He DID read the rule, he even sited it! He just did not understand it. Please do not jump on people like this.
Midfield Collisions Swampdude General Forum 36 31-01-2005 23:51
YMTC: Is it goaltending? Natchez You Make The Call 43 12-04-2004 18:03
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
