Tx/Rx pin layout?
I'm trying to connect the CMUCam from the FIRST kit to my vex controller. I know this is possible by connecting the TTL conveter for the camera to the TX/RX, but i don't know what pin of the three carrys data.
Re: Tx/Rx pin layout?
If you compare it to the standard input pin RED is +5, Black is Ground, White is RX/TX. If you are using a CMU CAM plug directly into its TTL port and skip the adapter board.
The easiest way to complete your "MOD" is to kill a pair of bump/limit switches and use the cable to make an adapter. |
| VEX inputs | Andrew Blair | FIRST Tech Challenge | 22 | 31-05-2006 18:17 |
| Encoders and putdata | theycallhimtom | Programming | 3 | 09-02-2006 19:24 |
| Attatching an axel to a wheel | Zoheb N | Technical Discussion | 36 | 12-12-2005 13:43 |
| joystick pin layout | fred | Control System | 1 | 29-01-2005 14:02 |
| Dynamic Input/Output Changing | Paolo | Control System | 6 | 23-09-2004 19:09 |
