Go to Post Guess i don't know what the secret weapon is, but i bet if it can be wedge shaped it is. - Chris [more]
Unread 27-02-2006, 03:32
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
How do you manage code changes?
I'm curious about experiences with the use of source code repositories (CVS, RCS, DARCS,...) and if anyone has been able to incorporate them into their teams development process.
We've tried but the use of a central repository has not worked well due to the fact that our development is on machines that are not regularly networked together. We archive the best code of the day and use it to seed a development directory for the next day's work.
What we have done that has worked fairly well, is use a contextual diff tool (KDIFF3) that provides a quick way to compare and merge two source directories. Using this tool, we can quickly see what has changed from a previous day's work, or we can merge separate development directories into one.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Problem with idata_user_routines.o? Adrien Programming 3 12-02-2006 01:33
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
