Re: How do you manage code changes?
I use subversion with Tortise . Elite Frontier will provide SVN hosting to FIRST teams for free (they already host 116 and 1418).
If you use TortoiseCVS check the User's Guide, it's simple. If you use a flavor of regular cvs look for "cvs update -j branchname". This means "join the branch to the mainline". Here is some documentation on Branching and Merging. |
We ended up with only one branch, when I completely rewrote our PID framework. I worked off the PID branch while everyone else worked from head. |
We used a dedicated laptop running Debian Linux (stable) as the server. I used cvsd to chroot the cvs pserver process. Each team member had a unique login and a trivial password*. I used viewcvs (now renamed to viewvc) as a web interface to let anyone without cvs knowledge browse the repository. We stored all kinds of stuff in the repository, not just our code. For example, we stored all the rules and updates and other documentation, our team roster, even photos of the robot.
We do not have internet access at our build, but do have an internal wireless lan. When we were at our build location, the cvs laptop is there. When we aren't building, it's at my house accessible over our dsl connection. The laptop ran a dns server such that when it was at our build location, you could use the same address as when you were accessing it over the internet. The commit philosophy we used was such that you should commit after testing when a test platform was availible, but if a test platform wasn't availible commit once you were happy and the code compiled. For our programming directory, we stored all the .c, .h, .lkr, .lib, .mcp, all the text readmes, and the .hex file. We wanted to have a complete history of the hex file so we could pull up exactly the program we used for each match, without worrying about library changes or other things like that. Right now we have a tag for the state it was after ship, and for after each fix-it window. We'll also have a tag for the code as it was in the robot for each match so that the drive team can easily request an old version. Depending on whether significant changes get implemented between matches, we may end up branching. *We'll probably be switching to a more secure form of authentication next year, I just wanted to get something that worked easily out of the box Last edited by Joe Ross : 28-02-2006 at 13:10. |
Copying entire folders like you are doing works. Just be very careful if you are going to open a workspace in one of the saved folders. MPLAB stores the absolute pathnames to the source code so it is still using the source files in the original folder, not the new folder! |
I've got SVN installed on my laptop (Hint: You don't need a server to use SVN with, file:/// repositories work fine). When I get home, I run a batch script that backs up the SVN tree to my desktop, then I have another script there which copies it over to my linux SVN server, so I can use stuff like ViewCV It also has the nice advantage of me having three seperate copies of the code, so I can't lose it. |
| Out of the Box Camera Code | russell | Programming | 9 | 21-10-2009 05:28 |
| Problem with idata_user_routines.o? | Adrien | Programming | 3 | 12-02-2006 01:33 |
| Code suddenly fails to initialize | miketwalker | Programming | 11 | 19-02-2005 15:23 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
