Go to Post NASA rarely launches another rocket just so the programmers can see if they've fixed a bug. - Greg McKaskle [more]
Unread 01-03-2006, 00:16
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Exclamation Anderson Connectors!!!!
My team needs more anderson connectors, does anyone know a site that we can order them from? we have looked at ifirobotics and andymark. can anyone help us, we need these ASAP!!!
Thanks
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 01-03-2006, 00:34
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Anderson Connectors!!!!
Thanks
This may surprise you, but check this out. At Cabela's Catalog number is 01-1811.
Not exactly where I looked first, but there they are!
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 01-03-2006, 01:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
http://www.powerwerx.com/
Unread 01-03-2006, 01:53
AKA: Cameron Dennis
Question Re: Anderson Connectors!!!!
We use red 50amp, 6 Gauge right?
www.frc1266.com
Unread 01-03-2006, 07:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
These are also available from Terminal Supply and they are sensitive to your immediate needs. The main battery connector is the 50 amp RED body. There are two types of terminals for this connector. The locking type is not supplied by FIRST but work fairly well. The stock type is what is supplied in the kit. Crimping is critical on these terminals so if you don't have the required crimper follow up with soldering before assembling.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-03-2006, 15:09
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
They are also available here.
Are you sure, I thought the main connector was a 175 amp dual powerpole connector. After all why would first give us a 120 amp breaker and 50 amp connectors?
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 01-03-2006, 15:14
Unsung FIRST Hero
Rookie Year: 1996
Take a close look at the marking on the connecter, all will be revealed. The reality is that the 50 amp connector, when not abused, can handle the current of a normal robot for a two minute match without self destructing. Any abuse (scratching the surface of the contact, misalignement, etc.) or inefficient robot design will heat the connector. The 50 amp rating is continuous current draw as is the 120 amp rating on the circuit breaker.
Al
WB9UVJ
www.wildstang.org
Unread 01-03-2006, 16:41
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
We made the fatal error and bought five of the 175 AMP connectors and promptly found out that they are the wrong size. Buy the 50 Amp ones instead.
Eat, Sleep, Build Robots
Unread 02-03-2006, 00:38
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
That link is NOT the right connector.
They are 50A SB-series red connectors. The red connector on that link is an SB175, and the blue SB50 will NOT mate with a red SB50. Each color is keyed differentally for the SB series, but the powerpoles are not. As others have stated they are indeed the 50A connectors, and are SB series, not powerpoles.
The 75A PowerPole contacts are the same as the SB50 50A contacts. Tells you something about the current rating...
You can get the contacts from McMaster (the 75A powerpole ones), but if you need the entire connector aseembly you are best off with terminalsupply co, powerwerx, etc.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 06-03-2006, 19:20
mechsham mechsham is offline
mechsham is an unknown quantity at this point
Hey there. Try....www.waytekwire.com I use them to order for work needs. They are very good about shipping-track#'s and pricing. Good Luck. shane
Thanks
Inventor Model: Small Anderson Connectors CraigHickman Inventor 0 31-01-2006 22:55
How to take apart anderson connectors M. Hicken Electrical 7 03-02-2005 08:53
Restricted to the Anderson Connectors in the Kit? sanddrag Electrical 15 20-01-2005 11:36
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
