Go to Post Krispy Kreme and Diet Coke. Accept no substitutes! - dlavery [more]
Unread 06-03-2006, 00:42
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Rookie Year: 1999
Ryan Meador will become famous soon enough
Re: The 8.2 (or 8.3) Battery Voltage Bug
I have some information that may be relevant. There is a problem with the silicon in the PIC chip that involves the interrupts not properly restoring register values upon return. I'm not sure if this could cause the problems you're all reporting, but the possibility exists - it may be this problem that the new libraries are supposed to fix.
You can read about this and other errors in the silicon of this line of chips here: http://ww1.microchip.com/downloads/e...doc/80221b.pdf
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
Unread 06-03-2006, 08:10
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
At least with Team 95's code (which does use an interrupt handler, but just for the Timer2 and ADC), the new libraries don't fix this problem.
Unread 06-03-2006, 09:56
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
The new libraries didnt fix are problem. And the only interupts used are with Kevin's code.
Unread 06-03-2006, 11:02
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
We had this problem too - our workaround was to stop using structures. It seemed that even having a simple struct of a few integers would cause rampant corruption and crashing. I'd suggest that as something to try if you're at your wit's end...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 06-03-2006, 11:03
kaszeta's Avatar
I just talked with IFI (and was talking to the same IFI rep that was at BAE), and they are looking at the issue and are going to call me back.
Unread 06-03-2006, 11:08
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Just FYI, IFI uses the high-priority interrupt for SPI communications between the master and slave processors. You just can't get away from those pesky interrupts <grin>.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 06-03-2006, 12:16
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
We were using a struct too, in our auto routines....
Has everyone here with this problem used a struct? It'd be funny if it was something as simple as that, but just checking...
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 06-03-2006, 13:30
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
Originally Posted by Keith Watson
The compiler creates a section of code in the binary where all of the static initializers are called. I have always assumed any sort of processor reset would call this block of code before calling main().
We encountered behavior where the symptom is that the static initializers are not being called by a reset under certain conditions. See the recent thread Camera does not search in autonomous mode after reset for a full description of those conditions.
We don't initialize any variables in the code, but instead in each file have an explicit initialize routine such as void InitializeRealTimeClock(void) that performs the initialization. If you write code this way, you don't have to worry about what the loader will or will not do to initialize bss and data. We put all the init calls that were used for autonomous just above the inner loop as well just so we could toggle the competition port pin to test the autonomous routine over and over without hitting reset. - Didn't help with the "8.2" problem though.
Unread 06-03-2006, 13:32
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Originally Posted by kaszeta
I'm wondering if there is some sort of memory stomping happening, because I've also seen some random bits flicking on the OI status leds (the pwm and relay leds; we had disabled the default routine LED feedback on these to make a little bar graph showing how good the camera lock was, but after we pulled the camera I pulled the code for this as well, and we still would see random bits flicker in there).
I had the intermittent data "glitches" with the LEDs as well; the cure was to save sections .tmpdata and MATH_DATA as well as the default PROD in the interrupt handler #pragma. For example:
Code:
#pragma interruptlow InterruptHandlerLow save=PROD,section("MATH_DATA"),section(".tmpdata")
Also, this may be a stupid question, but is everyone here using the latest version of the IFI loader? The previous version had a problem writing to FLASH bank 1, which might explain why it works just fine as long as it can fit in the 2005 controller.
EDIT: What version of the compiler is everyone using?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 06-03-2006, 14:23
FRC #2429
Originally Posted by Eldarion
...What version of the compiler is everyone using?
You beat me to this question. I'm using 2.44 (version can be found in readme.c18) and have seen *none* of the problems teams are seeing. All of the code on my website has been compiled with the 2.44 version. Has anyone had a problem with the pre-compiled code in my .zip files?
-Kevin
Kevin Watson
http://kevin.org
Unread 06-03-2006, 14:28
kaszeta's Avatar
Yes. I can regenerate the 8.2V problem with the gyro.hex file from a freshly-downloaded frc_gyro.zip from http://www.kevin.org/frc/, although it doesn't do it every time I upload it.
So far, the IFI folks think that ADC_Int_Handler() is too long, but I'm not sure I agree (since I'm not seeing the RLOD, and it works flawlessly on my 2004 RC).
Oh, and to answer your question, I'm using mcc18 v2.40. (Is an update available to us?)
Unread 06-03-2006, 14:50
Sachiel7's Avatar
AKA: Shayne Helms
Yes, we are using v 2.40 as well, this is the version that was supplied in the kit. Did we miss an update? I don't recall seeing anything come across the board...
Perhaps that is the root of our issues,
From the IFI Website:
NOTE: To Compile 2004, 2005 or 2006 code, use MPLAB ver 7.20 and C18 Compiler ver 2.40 (newer versions can not be used)
Kevin...you didnt give us base code compiled with 2.44 did you...?
Even if so, we do appreciate all the hard work you do to provide us with the code each year, so Thank You!
-=Sachiel7=-
Unread 06-03-2006, 18:01
FRC #2429
They're referring to version 3.0 of the compiler, which cannot be used for a few different reasons.
Yep, I certainly did. It's not a problem.
As long as you learn something from reading/using the code, it's my pleasure.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-03-2006, 18:27
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I'm using 2.40 and I haven't seen any of the problems stated here.. The real test will come on Thursday, when I see if any of these problems have appeared since we put it in the box...
I'm going to check tonight to see if we have a spare 2005/2004 RC that we can bring, but as of the current FIRST rules, they are not allowed. Maybe someone should go post on the Q&A forums, explaining the situation.. maybe we could get the 2005 RC cleared to use until this problem is resolved (It DOES work with the field control system, we were using it at the scrimmage with no problems) It wouldn't even be a tight fit for me.. 55% usage on the 2005 controller
Someone with access to a 2006 RC: Disable compiler optimizations... Project->Build Options->Project->MPLAB C18->Optimization (Dropdown), Disable.
If that fixes it, then its a compiler bug (But it can be worked around!)
I can tell you right now I've had all the optimizations enabled since the second week of build, and haven't seen this problem.
  #15   Spotlight this post!
Unread 06-03-2006, 21:05
kaszeta's Avatar
And neither did we, with almost 100 hours of autonomous mode testing in our clubhouse. At BAE we were batting 50%.
Under the circumstances, you can probably get a ruling on the field. They originally gave us trouble last year about subbing a 2004 RC for our 2005 when we broke a terminal off of it, and they eventually calmed down.
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
