Go to Post I think the best driver team of the post season would be Mike Wade and Pete Baltzell- because they have been driving that NASA field all over the Northeast so all of us can play.Thanks guys!! - Wayne C. [more]
Unread 03-03-2006, 02:23
bayside bayside is offline
bayside is an unknown quantity at this point
Lowering of Arms
Hi guys i need advice on lowering one of my arm in a slow motion without the use of any motor or gear(if possible),cause my PCB doesn't have anymore port for motor.i am thinkin of spring or other means,which can lower the arm in a slow motion,because for now,the moment when the string hanging onto the arm is being let loose it just roll,so now i was hoping to come up with an idea that it can slow up the speed of lowering the arm and let it drop in a gracefully manner.
Unread 03-03-2006, 07:18
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Lowering of Arms
Gas shocks (the type used for the rear gate on cars and minivans might help.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 03-03-2006, 07:22
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
A gas shock is a good idea (you beat me to it) But if that is too strong, you can take a regular pneumatic cylinder add flow restrictor valves on both ends of the cylinder. This will let you control the speed at which gravity pulls down the arm. And if you want you can add an air pump and actuate it then
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
can we use our arms as measuring devices railerobotics FIRST Tech Challenge 1 04-02-2006 13:24
What is best for lowering the middle wheel? Jeff K. Technical Discussion 9 28-01-2006 12:49
Truss designs in arms Max Lobovsky Technical Discussion 9 27-01-2005 13:30
pneumatic arms Jesse Control System 1 06-02-2004 15:41
What do you think of team 61 robot Walter_Jr Robot Showcase 69 01-04-2003 11:41
