Go to Post But then again, no one's robot ever is fully working to how they want it before the first tournamant. - #1Transgirl1140 [more]
Go Back   Chief Delphi > Other > Math and Science
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 08-03-2006, 15:30
chez0011 chez0011 is offline
chez0011 is an unknown quantity at this point
Naked Egg Drop- Any Experience?
No, this is not about Skinny-dipping!!!
I have a physics project where I need to drop a grade-A large egg from 7 meters into a "catcher" The catcher has no restrictions except that the first thing the egg touches cannot be over 10 cm high. I get extra points for a working catcher under 5 cm. No points if egg bounces and breaks on concrete or for missing the catcher. No hard-boiled eggs.
Any experience shared would be appreciated. I would like to cut down on research and development time if possible. I have until 3-21-06 to complete this.
My thoughts;
1. choclate pudding
2. sheet with small weights on corners draped over a 10cm box-possibly with a low density foam instead of a bottom, just sidewalls on box.
3. Soak egg in a solution rendering it more elastic-last option.
4. layered sheets of paper with 1/2cm spacing.
Unread 08-03-2006, 15:36
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Naked Egg Drop- Any Experience?
Originally Posted by chez0011
My thoughts;
1. chocolate pudding
My personal experience is that tapioca pudding has superior cushioning properties
I suppose the chocolate would be more delicious afterwards...
Unread 08-03-2006, 15:39
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
there was a great thread on egg drop contests earlier this year - lots of good ideas - try the search function to see if you can dig it up
Ive heard the best material for catching /cushioning eggs is grass clippings (from your lawn)
Since you are in the great white north, maybe someone in california can send you a box of grass in the mail?
Unread 08-03-2006, 16:11
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
we did one but not 7m high. we had to have it on a rubber band car and launch it off a table. i used a balloon, the kind you twist into animals and stuff. twisted it around under the egg worked perfectly.
but in your case i think its too bouncy. tempurpedic is also a great idea my friend used. free sample chunk if you call to ask about it or sumthing. call a couple times lol.
Unread 08-03-2006, 16:20
Elyse Holguin's Avatar
Elyse Holguin Elyse Holguin is offline
thinks Allison Babcock & 1747 ROCK!
AKA: goosefrom71
FRC #1747 (Harrison Boiler Robotics/ Team Hammond)
Elyse Holguin has much to be proud ofElyse Holguin has much to be proud ofElyse Holguin has much to be proud ofElyse Holguin has much to be proud ofElyse Holguin has much to be proud ofElyse Holguin has much to be proud ofElyse Holguin has much to be proud ofElyse Holguin has much to be proud ofElyse Holguin has much to be proud of
Send a message via AIM to Elyse Holguin
Hey! I did this for Science Olympiad back in high school. We won the regional competetion and placed fairly well at the state competition (Indiana), probably would have done better if my partner would have not gotten nervous and completely missed the target towards the end...
Anyways, we used buckwheat, like the inside of the Sabakawa (however it's spelled) pillow from back in the day. Wow. Add me to the list of "we're feeling old."
PS- a good and easy way to make an egg more elastic is to soak the egg(s) in vinegar (plain white will do) for at least 3 days. Just be careful and make side walls- it'll bounce like a ball (this was my 5th grade science experiment). Also, I never dropped the vinegar egg from higher than 3 meters, so you might ant to test that...
Good luck!
1747- Rookie Inspiration Award Winners @ Buckeye- 2006
Highest Rookie Seed- Buckeye- 2006
Autodesk Visualization Award- Buckeye- 2006
Rookie All-Star- Boilermaker- 2006
Technokats' Spirit of Indiana Award- IRI- 2006
Congrats to Allison Babcock- WFA St. Louis Regional!!
Former Member of Team Hammond 71: 2002-2004 +2001 CDI
Former Mentor for Team 1747: 2006
Unread 12-03-2006, 13:32
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
MEMORY FOAM! Well I was apart of something similar to this. Where you had to make a surrounding for an egg which you put the egg inside it and droped it from 30 feet. I made mine a box and inside it was a bunch of memory foam (developed by NASA )
I worked great for me. I just call a bunch a companies that sell this stuff, and they sent the form samples (4" by 4" by 1")
P.S. I am just suggesting the material.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 20-03-2006, 00:17
Ok, Here is what I found that worked for me. I was limited on time etc. so I just used stuff from my garage, fortunately I've been doing construction lately and happened to have some 3.5" fiberglass insulation, lumber and plastic.
I cut a cardboard box to 10cm. high, laid 3.5" fiberglass inside, then I cut a piece of 2 mil plastic about three feet longer than each end of the box. I laid the plastic over the box of fiberglass, laid two 2X8 pieces of lumber over the excess plastic, wrapped the plastic around the 2X8's and pulled the plastic taut. I dropped a jumbo egg from 30 feet and made it on the first try.
When the egg hit the plastic, the boards moved slightly toward the box and slowed the egg down enough for the fiberglass to finish the job. The very light 2 mil plastic helped too. The variable here would be how heavy the boards are, extra weight may be needed depending on the species and dimention of the lumber used.
Thanks for all you ideas, I didn't use up too much of my spring break working on it. If this initial try hadn't worked I was going to make an airbag system with a variable speed 12v. blower that would have been a big pain in the.... and if the air bag didn't work I was going to soak the eggs in vinegar. And if that didn't work I'm not sure what I was going to do cuz I didn't have time to send off for memory foam, I guess I would have been eating scrambled eggs!
Thanks again,
Brent
Unread 28-11-2007, 18:38
Physicsphreak Physicsphreak is offline
Physicsphreak is an unknown quantity at this point
I have a physics experiment to use only 5 sheets of regular computer paper and 1 meter of masking tape to build something to hold a raw egg and drop it from 10 feet and then drop it from almost 30 feet. Whichever model can prevent the egg from cracking at all, and has the overall lowest mass wins and receives more points for the project. Any possibility anybody can suggest any ideas?
Unread 28-11-2007, 19:20
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Use two piece of computer paper to make a "cone" or "rocket." Use 1 computer paper to surround the egg and use the 2 piece of computer paper and make a "cushion" around the cone (on the pointy side).
When you drop the cone, point it down. As the pointy side hits the floor, the pointy side will take the impact. As long as you can securely place the egg, it shouldn't crack.
I had a similar project to do back in my sophomore year in high school, but I was allowed to use newspaper. I dropped it from the 5th floor, it didn't crack. Try it out and let us know how it went.
As for the other project, try using the memory foam like Arkorobotics suggested.
Unread 28-11-2007, 23:20
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Arefin, Naked Egg Drop. Nothing on the egg, all absorbing material below it.
That said, there's one over-arching design contraint. Your egg will be falling at ~11.7 m/s at impact, and you'll have to decelerate it at around 70g's for a 10cm stop and 140g's for a 5cm stop. At least. This is an absolute, even if you're trying to deflect the egg and have it come shooting out the side, since you have to arrest the downward velocity no matter what.
So you best is probably to absorb all the energy directly. This is the buckwheat hull, chocolate pudding strategy. This is easy to understand and implement. You can take some advantage of the strength of an eggshell under well distributed pressure. You'll be able to make a very wide landing pad for easy aiming. However, I think you'll discover that as your drop height increases, the thickness of absorbing material you need will increase linearly with it. That is, twice the height = twice the pudding.
Anyways, pulling off something like that is mostly just a matter of trial, error, and a decent plumb bob for aiming. I think there might be much better, much more amusing options depending on just how specific those rules are. Yes, we're talking loopholes now. My first thought is whether air counts as something touching your egg. If not, a blast of air could extend well upwards of 10cm to start gradually decelerating the egg well ahead of time. I'm basically thinking of the nifty physics demo you see in science museums of tennis balls hovering over very noisy traffic cones. In your case, if air doesn't count, you could actually make a 7 meter tall wind tunnel with probably 2 leaf blowers attached to levitate your egg. Expensive? Yes. Complicated? You betcha. Worth it to see your egg float 7 meters down to the ground to land softly on a gilded 4cm tall pillow? Well you'd have to be the judge of that.
Unread 28-11-2007, 23:44
AKA: Ari
Physicsphreak posted right before me and asked for a suggestion on a project he is working on. That's what I was responding to. =)
Unread 08-03-2006, 16:10
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
My thoughts;
1. choclate pudding
Ever see how stuntmen jump off 3 and 4 story buildings, as if they were Bruce Willis? The human body is very much "the egg" in these stunts.
They basically have a bag of air that the stuntman jumps onto, but it has openings as well that allow the air to escape quickly enough that he isn't hitting a solid surface, but slowly enough so it cushions him and absorbs the energy before he hits the ground. You've got to figure out what the proper flow rate out of the bag is, so all energy is dissipated as the egg finally reaches the ground.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Egg drop Contest- Help Please!! bighpfreak Math and Science 41 05-11-2005 13:21
please help me! its an egg drop contest jess Math and Science 13 09-09-2005 21:20
The Egg Drop Project Joe Matt Math and Science 1 20-05-2005 13:05
nother egg drop contest SchmitTheNordic Math and Science 11 30-04-2004 23:25
A testimony to my unique FIRST experience: Ken Leung General Forum 22 14-04-2004 20:45
