Go to Post Note to self for next year, apply physics rather than "well, this SEEMS like it would work." - Karibou [more]
Unread 08-03-2006, 21:12
general's Avatar
general general is offline
That's me!
AKA: Bryan
FRC #0213 (Dirty Birds)
Team Role: Webmaster
general is an unknown quantity at this point
Send a message via AIM to general
php/forms/posting/I NEED HELP!!!!!!!!!
I want to put a comment/quotes page on my teams site, and let people submit their own, but I don't know anything about php or any other database. Can some one help me?
http://www.khsfirst.com/
Unread 09-03-2006, 07:51
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: php/forms/posting/I NEED HELP!!!!!!!!!
There are a few options. One is to use a free shoutbox type program. Another is to use php and log all of the comments to a text file. The last option is to use php and save it all to a database. The last will be the hardest to code but could allow for more features to be added. If i have any free tome today i will write you some sample code.
Unread 09-03-2006, 11:14
Team 2021 Captain
AKA: Chris Davidson
CHeck out these links. http://www.project-angel.com/index.p...&cat=PHP&id=13 and http://www.project-angel.com/index.p...&cat=PHP&id=14 . Hopefully that will get you started. If you need any help just ask.
Unread 11-03-2006, 23:59
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
I actually think that writing it to use a database (MySQL for example) would be easier than using the text file. That's just what I'd do, though. Either that or use XML..
Unread 12-03-2006, 16:22
Team 2021 Captain
AKA: Chris Davidson
With a text file there would be no need for a MySQL database (not sure if he has one). Plus, he wouldnt need to know SQL or and knowledge of XML. WIth XML you have to parse all of it. With a text file he could just log everything as a line of text.
Unread 12-03-2006, 17:32
general's Avatar
That's me!
AKA: Bryan
Could some one give me the code for the text file option.
Unread 12-03-2006, 18:49
Team 2021 Captain
AKA: Chris Davidson
Just to confirm what you want, you want a box that holds the posts of the shoutbox, under that you want a spot for people to input a nickname and message. Will that work for you? Also, do you know what version of php your webserver is running?
Unread 14-03-2006, 14:43
general's Avatar
That's me!
AKA: Bryan
Here is the server info:
Unread 14-03-2006, 15:02
general's Avatar
That's me!
AKA: Bryan
And I would want it to look like this
http://www.khsfirst.com/insert.html for the submiting page, and http://www.khsfirst.com/Quotes.html for the pageit would show up on.
Unread 14-03-2006, 15:45
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
ya know, it would be a ton easier to just use a database.
if you have PHPmyAdmin, then use it.
PHP Code:
mysqlServer mysql_pconnect("server","username","password"//server is typically "127.0.0.1"
mysql_select_db("siteData"mysqlServer);
$getNews mysql_query("SELECT * FROM `news` ORDER BY `id` DESC");
$rowGetNews mysql_fetch_assoc($getNews);
$numRowsGetNews mysql_num_rows($getNews);
do {
echo
$rowGetNews['body'];
} while(
$rowGetNews mysql_fetch_assoc($getNews));
im assuming that you have a database, schema name "siteData", with a table called "news".
columns should be AT LEAST:
id INTEGER AUTO_INCREMENT, title VARCHAR(35), body TEXT
adding news to the DB is a different story.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 14-03-2006, 17:54
general's Avatar
That's me!
AKA: Bryan
Ya what is PHPmyAdmin? And how do I Use it?
Unread 15-03-2006, 08:01
Team 2021 Captain
AKA: Chris Davidson
phpMyAdmin is a php based MySQL admin tool. If you have CPanel then it is included, else you have to set it up.
The databases can be created without phpMyAdmin. I can write up some code for inputing data and createing the tables if you want me to. Also, can you find out if your webserver supports PHP and if so what version. If you cant find it, please post a link to the people who provide your hosting.
EDIT: I wrote this up quickly so its not that great but it will work.
PHP Code:
Database Layout
Database --> "siteData"
Table --> "news"
columns --> id INTEGER AUTO_INCREMENT, title VARCHAR(35), body TEXT
// Code for printing out all of the news
// Connecting, selecting database
$link = mysql_connect ("server","username","password") or die ('I cannot connect to the database because: ' . mysql_error());//Open up the specific database
mysql_select_db ("siteData");
$query = ""SELECT * FROM `news` ORDER BY `id` DESC"";
$result = mysql_query($query) or die('Query failed: ' . mysql_error());
echo "<table>\n";
echo "\t<tr>\n";
echo "\t\t<td>Name</td>\n";
echo "\t\t<td>Post</td>\n";
echo "\t</tr>\n";
while ($line = mysql_fetch_array($result, MYSQL_ASSOC))
   echo "\t<tr>\n";
   foreach ($line as $col_value)
       echo "\t\t<td>$col_value</td>\n";
   echo "\t</tr>\n";
echo "</table>\n";
// Code for adding news to the db
Add Post
<FORM ACTION="<?=$PHP_SELF?>" METHOD="POST" NAME="newsentry" type="text">
Name:
<BR>
<INPUT TYPE="text" SIZE="50" NAME="name" type="text">
<BR>
Post:
<BR>
<INPUT TYPE="text" SIZE="50" NAME="post" type="text">
<BR>
<INPUT TYPE="submit" NAME="submit" VALUE="Submit">
<BR>
</FORM>
if($HTTP_POST_VARS['submit'])
        if(!
$HTTP_POST_VARS['name'])
            echo
"You must enter a name";
            exit;
        if(!
$HTTP_POST_VARS['post'])
            echo
"You must enter a post";
            exit;
$query "INSERT INTO news VALUES ('', '$HTTP_POST_VARS['name']', '$HTTP_POST_VARS['post']')";
$result mysql_query($query);
Unread 15-03-2006, 15:57
MattD's Avatar
PHP Code:
Database Layout
Table --> "news"
echo "<table>\n";
echo "\t<tr>\n";
echo "\t</tr>\n";
   echo "\t<tr>\n";
   echo "\t</tr>\n";
echo "</table>\n";
Add Post
Name:
<BR>
<BR>
Post:
<BR>
<BR>
<BR>
</FORM>
        if(!
            echo
            exit;
        if(!
            echo
            exit;
Ah, so you are going to go with the MySQL option. Honestly, to me that seems much more easier than using a text file..
Oh by the way (correct me if I am wrong), I see a SQL injection vulnerability in your code. It's not as if it'll probably ever cause any real problems, it's just that it exists.
PHP Code:
Plain text posted is being inserted into the query. So, in theory, someone could submit something that could potentially alter the query. My advice would be to look into using the mysql_escape_string() or the mysql_real_escape_string() function.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 15-03-2006, 16:19
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Or, he could just make sure that no one but an administrator can get to that page. Dont execute the query if you arent logged in!
PHP Code:
if ($_SESSION['UserClass'] == 'Admin') { }
or something like that. but if you do that, you would need to setup a login system.
I used to have a bunch of tutorials that i made about how to do this stuff.
RPI 2012
BREAKAWAY
  #15   Spotlight this post!
Unread 15-03-2006, 16:26
MattD's Avatar
Well, sure.. but that still doesn't solve the SQL injection vulnerability. I think he wants just anyone to be able to submit, anyway.
