Go to Post My father taught me long ago that how we respond to adversity is what defines us as human beings. Let's all keep this definition in mind as we move forward to change a culture. - Rich Kressly [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 09-03-2006, 17:23
neslo89's Avatar
neslo89 neslo89 is offline
CAD/CNC extraordinaire
AKA: Trevor Olsen
FRC #0871 (West Islip Robotechs)
Team Role: Animator
neslo89 will become famous soon enough
Send a message via AIM to neslo89
Exclamation Driving Contraint Error
I am trying to drive a mate constraint but after driving it an error pops up. It says:
"Cannot solve at (or near) this point. Check drive parameters and adaptivity settings."
Can anyone help me get rid of this or tell me what the problem is?
Thank you for any help
Unread 09-03-2006, 20:03
CraigHickman
Posts: n/a
Re: Driving Contraint Error
More info is really needed. Also, a picture is worth a thousand words, so that would help too. And by a picture, i mean one where we can clearly see the area where you're tying to constrain.
Unread 09-03-2006, 20:54
neslo89's Avatar
AKA: Trevor Olsen
Team Role: Animator
The front of the circle is mated to the back of that triangle-like shape. When I try to drive the constraint i get the error.
Unread 09-03-2006, 21:04
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
The most likely thing that will happen is the part could:
1) Be over constrained (two constraints for the same thing)
2) It is causing other constraints to fail such as a pivot point wont move or a part is constrained not to slide when it should.
3) The two arts being constrained do quite match up right and are causing an alignment problem (.00000000000...000000000000001 in cad is too much off)
I would have to look at the file and see for myself what it is. But thanks for the picture it really helped.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 09-03-2006, 21:08
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
Team Role: Teacher
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
I've been working to help trevor solve that problem. The parts can slide freely if dragged with the mouse, and if you manually set an offset at 1 inch increments it works without any errors. BUT , as soon as he tries to drive the constraint it moves about 1-2 inchs, stops, and then pops up the erros that he posted above.
He's been working on this for 2 days and we're starting to run out of excuses as to why it won't work.
~ Mr. Buonomo, Team 871
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Persistent "no robot controller found" error 1594code Programming 12 20-02-2006 20:59
Screenshot of "code not understood" or similar error needed! Elgin Clock Programming 3 17-02-2006 22:06
IFI Error iwdu15 Programming 3 09-02-2006 18:11
MPLink Error cloudago Programming 2 01-02-2005 23:00
