Go to Post [A screen shot] is very helpful - I've sent Brandon many of those the various times I've broken ChiefDelphi.com! - Jessica Boucher [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 10-03-2006, 22:28
aubinhick990 aubinhick990 is offline
Programmer
FRC #0238 (Cruisin' Crusaders)
aubinhick990 is an unknown quantity at this point
Send a message via AIM to aubinhick990
Logic Question
This is a PHP website....
Okay, I have these variables...
PHP Code:
$itemE_year
    $itemE_month
    $itemE_day
    $itemE_hour
    $itemE_minute
    $itemE_ampm
    $year
date("Y");
$month date("m");
$day date("d");
$hour date("h");
$minute date("i");
$ampm date("A");
Basically they're self-explanatory....the $itemE_x is just a number being assigned via the contents of a text file.
Now, my question is what logic would I need if I wanted to check if the Item's year/month/day and hour/minute has passed my server's year/month/day, hour/minute.
This is the logic I've come up with but it doesn't work quite right...
PHP Code:
if(  (($year >= $itemE_year)) )
    if(
$month == $itemE_month)
      if(
$day >= $itemE_day)
$DISPBOX "false";
        echo
"Time has passed!";
    if( ((
$hour >= $itemE_hour) and ($minute >= $itemE_minute)) and ($ampm == $itemE_ampm) )
Whatever else I'm doing....
Any suggestions? Thanks a ton!
Unread 11-03-2006, 11:06
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: Logic Question
Is there any reason you can't store time() instead? If you need the d/m/y out of it later, you could use date() then.
Otherwise, the simplest way would be to use:
PHP Code:
if (strtotime("$itemE_month/$itemE_day/$itemE_year $itemE_hour:$itemE_minute $itemE_ampm") > time()) { echo "yup"; }
It's more intensive than checking the logic but it's far simpler.
PHP Code:
if ($item_year $year) { echo "yes"; }
if (
$item_year == $year) {
  if (
$item_month $month) { echo "yes"; }
  elseif (
$item_month == $month) {
    if (
$item_day $day) { echo "yes"; }
    elseif (
$item_day == $day) {
      if (
$item_hour $hour) { echo "yes"; }
      elseif (
$item_hour == $hour) {
        if (
$item_minute $minute) { echo "yes"; }
Another way would be:
PHP Code:
$old = array(
$item_year,
$item_month,
$item_day,
$item_hour,
$item_minute
$new = array(
$year,
$month,
$day,
$hour,
$minute
function
compare_dates($old$new) {
for (
$i=0;$i<4;$i++){
if (
$old[$i] < $new[$i]) { return "no"; }
if (
$old[$i] > $new[$i]) { return "yes"; }
return
"equal";
echo
compare_dates($old$new);
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 11-03-2006, 16:45
Programmer
Re: Logic Question
Wow thanks a lot. I can't do it right now but I'll work on that ASAP and get back to you about how it goes. As you can tell, I'm pretty novice when it comes to PHP but am still learning.
Important question regarding starting position of balls in the BOT Nimmy Rules/Strategy 2 12-02-2006 17:17
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
Why I hate Logic EnderofDragon Chit-Chat 2 19-02-2002 21:02
