Go to Post Whoooo, just got my wheels from AM! Sometimes it's cool to live in Indiana. - IndySam [more]
Unread 15-03-2006, 18:23
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Team Role: Mechanical
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Live axel on kit skyways?
I tried to search this and didnt find exactly what i wanted but ill give it a shot.
We need a quick way of mounting the kit skyways to shaft that is smaller than the ID of the skyways. we dont want to have to use many machine tools since our resources are limited. is there an easy quick way to do this?
any ideas welcome
thanks Bill
MechWarriors 573
Unread 15-03-2006, 18:52
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Live axel on kit skyways?
There are two answers.
If you want to run a shaft through the bearings, which are 3/8", just get an aluminum spacer. For example, if you want to run the wheels on 1/4" shafts, just get an aluminum rod with 3/8" OD and 1/4" ID. These are very common at OSH, in fact our robot uses a bunch of that metal for our manipulator. However, the ID is actually less than 1/4", so we just drill it out on a drill press. You have to be careful to keep concentricity, but it can easily be done. So yea, just drill that stuff out to whatever
ID you want.
If you are talking about taking the bearings off the skyway and powering it, like having a shooter wheel on a powered shaft, it can also easily be done. The bearings are .875 OD, so the hole in the wheel is .875 ish. However, there is a flange to keep the bearings from going in, which has an OD of a little less than .750". You can press a .750 shaft into it, which can have the proper bore drilled into it for your uses. This can't take too much torque, but its easy. If you want it to take more power, this is what my team did for our shooter wheel:
We drilled out the flange (making a through .875" hole in the wheel) and glued in a cylinder of aluminum with a .875" OD and .5" ID, which was keyed. Along with the glue, we used four steel rivets through the wheel and into the aluminum to transmit most of the torque. It is a very nice and easy way to do this, and you just need a drill press. (or if you're really skilled, a hand drill). I'm sure if you guys dont have a drill press, there would be some team willing to let you use theirs. Just make sure you have a .875" drill bit, and use a low cutting RPM
Unread 15-03-2006, 18:55
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
For what it's worth, remember that the bearings on the 8" Skyway wheels accept a 3/8" diameter shaft while those on the 6" wheels accept a 5/16" diameter shaft.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 15-03-2006, 18:53
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
The bearing wouldn't work if it is a live shaft I don't think... try finding some thick-walled tubing, and set-screwing it to the shaft, then fix the wheel to the tube.
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
For some non-drive applications, we've used bronze bushings to adapt from an over-sized bearing onto an undersized shaft. They take up much less room than a bearing, so it's easier to find sizes that fit. Otherwise, if you can find some tubing that fits just right, you're all set.
What diameters are you trying to fit together?
BEN
Unread 15-03-2006, 18:59
Originally Posted by TubaMorg
See if you can find some bearings with the same OD as the kit bearings, but with a smaller ID (as in the size you need).
Good idea. In fact, here are some bearings that would work for this:
Mcmaster parts:
6383K14 -- 1/4" ID, 7/8" OD, 1/4" wide
6383K15 -- 5/16" ID, 7/8" OD, 1/4" wide
Your standard, open ball bearings, less than 4 bucks each.
Just tap out the old bearings, and hammer in the new ones.
Madison - while the 8" skyways are always 3/8" sealed plain bearing wheels, you can order the 6" skyways with either 5/16" flanged bearings or 3/8" plain bearings. Our 2005 and 2006 both use 6" skyways with plain 3/8" bearings.
Unread 15-03-2006, 19:33
AKA: Bill Hancock
I need the wheel to be driven for the shooter
MechWarriors 573
Unread 15-03-2006, 19:42
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Ah, okay. I used 6" wheels we had laying about the shop and so I didn't realize you could specify what you wanted while ordering them. Good to know.
--Madison--
Unread 15-03-2006, 22:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
What I've done in the past for a prototype is found a washer that fits right into the little step in the plastic in the hub. Put ont on each side. Put some threaded rod through. Couple nuts to clamp those washers into the wheel real tight. Couple more nuts to hold the first nuts. You're good to go. Balance may be a problem though.
Unread 16-03-2006, 10:31
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
if you use a clamp type system using a piece of rubber inside as a spacer will help to eliminate vibration and keep it close to balanced if you take your time when making it
KK4KQO
http://voltair.us
Too many projects, too little time.
Unread 16-03-2006, 17:38
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
We used taper locks from McMaster Carr
We just bored the skyway wheel to 7/8" and put in the taper lock. We used a 1/2" shaft. McMaster sells these for all standard sizes. They are a little expensive, but they do a great job.
Here is the part number for the ones we used: 5926K16
Good luck!
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Live video with Kit Camera BobcatProgramer Electrical 10 11-01-2005 10:43
Coding CDs in the kit -- What'd you get? elyscape Programming 1 08-01-2005 14:31
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
Fav. Beatles Song MattK Chit-Chat 17 04-12-2002 17:18
