T_Packet_Data.mx vs PAN_SERVO
After scratching our collective heads over getting our turret to point AT the light instead of 20-degrees or so off, we dug into code with some printf's, and searched here to find some sort of answer. We have been using the .mx number for a pan angle, but in Kevin's code where the camera reports out the T_Packet_Data stuff, we find that it's using PAN_SERVO for the number (and converting it to degrees). There was also this tidbit from "Moving robot while tracking with camera questions..." (which I think I can manage to show at http://www.chiefdelphi.com/forums/sh...ad.php?t=42993 -- yes! I did it!) with this answer:
For the record, we are using the Bells and Whistles version of camera of Feb 20th. Roger. who somehow managed to code urls, quoting and bolding for the first time! Better than them angels singing! |
Re: T_Packet_Data.mx vs PAN_SERVO
Yea, the way Kevin's code behaves is it centers the camera dead onto the vision target. Therefore, the .mx should always be about dead-center (or half of 119). The PAN_SERVO gets adjusted to get the .mx to center. That's why you originally had it backwards.
If you find it's still slightly off center (maybe your camera is mounted crooked), you can tweak the #DEFINEs that set the default center for things in camera.h and tracking.h |
Thanks, Greg. But of course the camera guy _says_ the camera isn't mounted crooked, but we all know better.
We got the code working (again!) but this one was our #1 problem. Now all we need is a robot to test it out on!Roger. |
When I had centering problems, I just played around with the centre pixel values. I dunno if it was the best solution, but it worked pretty well
! I thought that was the problem for us when the camera was looking about 10 degrees off from the light.Ah, sorry I didn't see you were talking about your turret, not your camera. Well, maybe it might help others, so I will leave it here. Our camera wasn't centered on the green light. It was strange. Last edited by Denz : 18-03-2006 at 23:09. |
-Kevin |
Kevin, I thought I read the documentation, but the doctor said to stick to the caffene-free Mt. Dew, so it must been forgotten.
I think I misunderstood the T packet .mx description (sorry, don't know from where; I just pulled page 57 out for reference): "The middle of mass x value". I guess I placed too much faith that the T packet reveals all. And I'm not too worried about the software Gods being happy, I have to answer to a higher authority: the teacher in charge of our robotics club! Denz, our turret shooter rotates, and the camera sits on top of the shooter, so lined up with the centerline of the shooter the camera should be locked on target. Camera too far off target, the turret turns back to target. Unfortunately, camera and turret were way off from each other, not a few degrees, but 10 or more; not a calibration issue. The group in charge of the camera still has calibration to do, but that waits until we have the robot again in Boston. Roger. |
