Go to Post Instead of lowering a team's expectations, let's raise the amount of competitive resources available to them. ;) - artdutra04 [more]
Unread 20-03-2006, 17:42
Dr.Bot
Posts: n/a
Heads Up BOM! Bumpers!
Much to my surprise, the biggest problem with inspections were teams forgetting to bring their Bill of Materials. At least 7 out of 40 teams at SVR had this problem. Mostly they weren't rookies. In some cases, this was their second regional!
The second biggest problem were bumpers. Read the*!&# rules! Pool noodles
means pool noodles, plywood back means plywood back, easily removed means .......
Alan Federman, Lead Robot Inspector, SVR, Davis.
Unread 20-03-2006, 18:11
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Re: Heads Up BOM! Bumpers!
I reminded our head mentor of the need for a Bill of Materials about 2 weeks before the end of the build season, and I was told it would be taken care of. It was...by me, in the car up to Pittsburgh, at 5:30 in the morning. Oh well, it did actually get done.
I did manage to keep my team on track with the rules for the bumpers. They were constantly asking if we could use odd things for the bumpers, and it got to the point where this happened:
"Hey Stephanie can the bumpers..."
(very frustrated)"If it's not a pool noodle, plywood or a bolt, then NO!!"
(Semi-scared)"I was just going to ask if they can be made now."
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 20-03-2006, 21:48
duck1370 duck1370 is offline
AKA: duck
FRC #1370 (Thermogenesis)
duck1370 is on a distinguished road
for some unknown reason, the bill of materials is something that 1370 always forgets until it comes time for inspection. and its a real pain trying to write a bill of materials for a fully assembled machine...
Unread 20-03-2006, 21:55
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
I also became very familiar with <R35>. I not only knew it was <R35>, I got to know how far down to pull the slider bar to find <R35> in the .pdf
Unread 20-03-2006, 21:57
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
I feel your pain. We slipped up and left the BOM in the pit when we went to inspection. I always make sure the kids who make the BOM (the mad cadders) e-mail it to me so I have a copy just in case.
As for the bumperswhat do you consider easily removable. We ended up using 1/4-20 cap screws because we were uncomfortable using 1/4 turn fasteners for them.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 21-03-2006, 08:19
Dr.Bot
Posts: n/a
Easily removable means that if you get reinspected you can take them off, fit in the box, put them back on and make your next match.
We used a tape measure on two machines because it would of taken a 1/2 hour to remove, measure and put the bumpers back on. If I was a stickler for the rules, the number 2 seed would have been disqualified.
Unread 21-03-2006, 09:16
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
This should have been caught durring the initial inspection. It's hard to DQ a team when it has already passed.
Unread 21-03-2006, 09:27
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
It is hard to DQ a team -- full stop. No volunteer wants to do it.
However, I would not take the fact that the team had previously passed inspection into account when deciding or recommending a DQ. Many teams make changes to their robots after passing inspection. When this happens the team is responsible for requesting a re-inspection. This year I have seen several teams add bumpers or modify the method used to attach their bumpers after passing initial inspection.
Richard Wallace
since 2003
Unread 21-03-2006, 09:32
the_short1's Avatar
the_short1 the_short1 is offline
Head of Electronics
AKA: Kevin F.
FRC #1596 (Twin Saults International Instigators)
Team Role: Electrical
the_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to all
Send a message via MSN to the_short1
i have a question.. if your bumpers are covered with the fabric.. how can you tell that their pool noodles? do you rip it open to check?
-kevin
2005 GLR: 12th/58 Seed, Aliance: 1596, 910, 1447 (Semi Finalists) Website, Rookie All Star, Highest Rookie Seed, and 2 Peer Awards, my BIG thank you thread, PLEASE READ
2005 GTR: 11th/66 Seed, Aliance: 703, 1596, 1680 (Semi Finalists) Highest Rookie Seed & 1 Peer Awards
2005 Championship (Galileo): 36th/86 Seed Highest Galileo Match Score: 123:7 Thanks 447 and 121
2006 Website (Totally Revamped):Instigators1596.com
2006 GLR: 31st/61 Seed, Aliance: 835, 1213, 1596 (Quarter Finalists) Spirit & 3 peer awards, THX!
2006 Waterloo: 7th/31 Seed, Aliance: 1219, 1596, 912 (Semi Finalists) Spirit & 2 peer awards, THX!
2006 Waterloo: Aliance: 1596, 1680, 1114 Higest Match Score: (Q22) 128|32
Unread 21-03-2006, 10:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Alan,
How strict are inspectors being on the securely fastened bumpers rule? I'm seeing a fair number of bumpers on the field. Meaning, more than zero. At GLR, our robot got wedged on top of an opposing team's bumper because they only secured it with wood screws. I believe one robot at Peachtree had to remove its bumpers because they simply wouldn't stay on. There's a fine line between easily removed and... well... easily removed in the course of a game.
pic: Team 1817's Black Widow 118 Tech Robot Showcase 14 25-02-2006 11:04
bumper customization? gondorf General Forum 20 01-02-2006 19:30
Early Release Field Elements BOM. Dr.Bot General Forum 52 05-01-2006 14:35
coins in a dark room Denman Math and Science 22 18-10-2005 21:18
The BOM, people, the BOM! rolocroz Rumor Mill 2 06-01-2004 20:28
