Go to Post Crazy is relative - dtengineering [more]
Unread 04-06-2002, 23:18
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
laser guidence for a basic stamp brained valve cover racer
I'm trying to make a lserg guidence package for a first robot, and I need some help.
The photoelectric sensor which is hit by the laser is mounted on a disk which has a rotary pisition sensor on it. as the disk rotates, the sensor determines the position of the disk.
When the sensor is hit by the beam, the position of the disk determines how much steering correction is applied (how much the servo that controls the front wheels moves and in what direction)
I'm having trouble finding a suitable rotary position sensor (a single turn pot without a stop would be great, but i can't find one.
any one have ideas for a suitable sensor?
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
Unread 05-06-2002, 00:14
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Have you looked at the DigiKey catalog yet? check out their website if you haven't:
http://www.digikey.com
In the print catalog I have, there are all sorts of pots on pages 625-630 that might fit your needs.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
