Go to Post You'll find that there are plenty of teams and individuals who shout. You'll also find there are a smaller subset of teams and individuals that do. Those that do tend to be the ones that get their way. - Lil' Lavery [more]
Unread 30-03-2006, 18:45
SizzelChest330's Avatar
SizzelChest330 SizzelChest330 is offline
AKA: Elijah
FRC #0330 (Beachbot)
SizzelChest330 is just really niceSizzelChest330 is just really niceSizzelChest330 is just really niceSizzelChest330 is just really nice
Send a message via AIM to SizzelChest330
Vex Cheats
Alot of this stuff may be very basic...
But I was wondering if anyone else has done any modifications to vex parts to optimize your performance
A couple things Ive done:
Made a custom PWM cable that splits into two motor plug-ins to run two motors off one slot in the Vex micro controller
Took apart a servo to take off the final gear with the "brake" and replace it with a continuous servo gear to make it a regular motor.
Go Beachbot!
Unread 30-03-2006, 21:08
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: Vex Cheats
We've done the simplest thing I think is possible. We used the 5" wheels but removed the tread from them so that we have much better turning with our 4 wheel drive system. Prior to removing them, the 4" with the tread caused so much friction when trying to turn on carpet that we broke the clutch (since they don't work properly and break at the max torque instead of slipping). Of course having an 11 lb. robot for those motors probably isn't too nice when you only have 1 motor on each side driving.
Unread 01-04-2006, 14:10
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
Re: Vex Cheats
Has anyone used the wheel hubs from either the 4" or 5" wheels as gears?
Has anyone wrapped tank tread links around the tank tread drive cogs to make wheels?
Has anyone used the intake rollers as wheels?
(the sound pretty cool on hard flooring)
What about programming cheats?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 01-04-2006, 20:09
The Arizona Mentor
AKA: Andrew
Re: Vex Cheats
Never use the setMotor function, but instead setPWM, because otherwise all your motors momentarily lose power. Of course that's more a bug avoidance thing than a cheat.
Unread 09-04-2006, 23:12
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
Team Role: Teacher
Rookie Year: 2007
michael714 is on a distinguished road
Re: Vex Cheats
Here's something I discovered by accident:
If you use the default program that comes with the VEX (in other words, don't do any EasyC programming), you can control two motors and a servo with the RC transmitter. I just left the transmitter in the default Tank 2 mode and hooked a servo up to motor port 4. After that, I was able to use tank mode to control the two motors in the standard SquareBot setup and I was able to use Channel 3 (on the left) to control the servo. On channel 3, up and down controls the left motor while side to side controls the servo. I'm using the servo to pan a wireless vidoe camera from side to side. It's cool!
One bummer though: when I try to use EasyC to do any programming that includes RC control, this capability goes away. So, I just redownload the default program to get it to work again. If anyone knows how to retain the side to side servo control even when using EasyC 1.1, I'd love to hear about it. Thanks.
Unread 10-04-2006, 01:33
The Arizona Mentor
AKA: Andrew
Re: Vex Cheats
All that is happening in the default code is probably a direct write from the value of a channel to the value of the pwm with the same number. The left to right on the left joystick is actually channel 4 (channel 3 is only the up and down), so it is likely the value of the channel 4 joystick is being directly fed to pwm 4, which controls the servo.
There is a function in EasyC that directly writes a channel to a pwm, but I do not remember it off of the top of my head (EasyC is installed on my laptop, not my desktop). I think it is something like RxControl();
Unread 10-04-2006, 03:06
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Lightbulb Re: Vex Cheats
Two ideas:
Look for Erector set components that might work with VEX, since both are made of metal and use siilar building construction methods.
Consider using the rubber tread on LEGO parts an covering the VEX wheels, giving them more grip.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 10-04-2006, 20:06
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Re: Vex Cheats
erector parts can work wonders.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 13-04-2006, 17:47
Alex Burman's Avatar
Alex Burman Alex Burman is offline
∆o□
AKA: The Burmanator
FRC #0075 (Roboraiders)
Alex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud of
Send a message via AIM to Alex Burman Send a message via MSN to Alex Burman Send a message via Yahoo to Alex Burman
Re: Vex Cheats
Too bad erector drive shafts are round.
Anyone have any suggestions on how to get replacement/additional drive shafts aside from the metal and hardware kit?
The Burmanator
www.Roboraiders.com
http://www.myspace.com/burmanator
Unread 13-04-2006, 18:14
Gdeaver Gdeaver is online now
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Vex Cheats
!/8" key stock I believe will work or order from vexlabs.
Unread 16-04-2006, 22:26
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
Re: Vex Cheats
It does work, i bought about 5 feet for a few bucks at a local hardware store, however it is a tighter fit then you really want, I think the shafts that come with vex are a few thousands smaller, or the edges are more rounded ect.
Unread 16-04-2006, 23:48
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
Team Role: Coach
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
Re: Vex Cheats
Couple things:
As many said, Erector Set peices. The possiblities increase tremendously.
Vex Labs
Unread 17-04-2006, 05:38
jeffmorris jeffmorris is offline
jeffmorris is on a distinguished road
Re: Vex Cheats
I thought that I have an Erector Set but I couldn't find it. The Erector Sets are made by different companies. I think that the older Erector Sets are better than newer Erector Sets. The screws and nuts in newer Erector Sets are junk.
Unread 04-05-2006, 22:51
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Re: Vex Cheats
Has anybody here ever made thier own clutches or modyfied any other motor component?
Radio Shack to discontinue VEX? jeffmorris General Forum 52 24-03-2006 16:33
Vex and Lego Cyber Punk 234 General Forum 3 03-12-2005 22:50
Milwaukee VEX League Kevin Kolodziej Off-Season Events 7 05-11-2005 17:58
Vex Robotics Vex FIRST Tech Challenge 0 14-04-2005 13:48
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
