Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 01-04-2006, 18:13
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Battery Power
Does anyone know for sure if you can use and hobby battery pack for the VEX? or does it use some special connector and also what about the controller can you buy any other battery pack for that aswell?
thanks
--Sam
Unread 01-04-2006, 20:36
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
Re: Battery Power
most batteries work, Radioshack batteries (that are 7.2v) I think fit this connection. We use them, just check the connector on the batteries before buying them.
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 11-04-2006, 11:05
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Battery Power
Standard R/C battery packs, for both 7.2 volts ('bot) and 9.6 volts (transmitterr) have the correct connections and fit just fine. Good advice from "gdo" though, and bring the controller and transmitter with you to be 100% certain.
Don
Unread 11-04-2006, 13:29
Ken Delaney 357 Ken Delaney 357 is offline
FTC #101(Radnor Robotics)
FRC #0357 (Royal Assault)
Rookie Year: 2000
Ken Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to behold
Re: Battery Power
We bought some RC batteries and they work fine, but the leads are not as long as the ones on the Vex Batteries. You can also buy a connector repair kit at RS if the connectors are incorrect.
Don
“Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat.” ~Teddy Roosevelt
Thus spake the master programmer:
"A well-written program is its own heaven; a poorly-written program is its own hell."
Unread 13-04-2006, 17:37
AKA: Sam Couch
Re: Battery Power
Ok thanks everyone! I actually got the RS battery set for the VEX but i wanted to be sure i could get replacments if i ever needed to!
No power - no problem P1h3r1e3d13 General Forum 2 20-02-2006 07:18
Batteries Required?? thinkpad Electrical 28 19-04-2005 05:59
Automatic Power Swampcoder2 Control System 6 03-02-2005 17:08
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Control System Power Al Skierkiewicz Technical Discussion 0 25-03-2002 09:04
