Go to Post however, if i tried it i would probably end up setting my hair on fire - Henry_Mareck [more]
Unread 03-04-2006, 15:36
Chris 481's Avatar
Chris 481 Chris 481 is offline
Main Mechanic Team 481
FRC #0481 (The Hitchhikers)
Chris 481 is an unknown quantity at this point
Hex Couplers
Where can i buy the hex couplers and housing for the cim motors
ive looked all over the internet and i cant find a place that sells them
also if anyone has any advice on holomorphic drive i am designing one to build during off season
Unread 03-04-2006, 16:09
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Team Role: Leadership
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Re: Hex Couplers
holomorphic? you mean holonomic?
anyway, for holonomic, use mecanum wheels. they're harder to make, but allows you to push, and otherwise behave like a normal bot.
Cheers!
Tatsu
Unread 03-04-2006, 17:30
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Re: Hex Couplers
I'm not exactly sure about this, and someone please correct me if I'm wrong, but when buiding a holonomic drive, can't you also just use omni wheels rotated at 45 degrees from the chassis? Each wheel must be driven by individual motors but by using different sets of motor combinations you can move "sideways" and "forwards" without actually turning.
VEX Robotics Blog
Unread 03-04-2006, 17:35
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Re: Hex Couplers
That's correct. The same is true of mecanum wheels, except that they can be arranged in a more typical 4WD arrangement and some feel that there are great benefits to such a design.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 03-04-2006, 18:17
Chris 481's Avatar
Re: Hex Couplers
i designed the drive to use one motor for each of the wheels and they have there own transmission that i have also designed so each wheel is powered. But i cant find the hex couplers to build the drive train. Here is the picture.
Unread 03-04-2006, 18:20
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Re: Hex Couplers
Those hex couplers are from the kit of parts provided several years ago. They are no longer available commercially, as far as I'm aware, as they were made for FIRST by Nypro. That said, there are probably plenty of teams who have them laying about their shop with no good use for them.
Before you get too far along, however, consider the eligibility of such parts for use in future robotics competitions.
--Madison--
Unread 03-04-2006, 18:28
Chris 481's Avatar
Re: Hex Couplers
i could also use other suggestions for connecting cim motors to gears especially if i wont be able to buy them now.
Unread 03-04-2006, 18:31
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Re: Hex Couplers
Well, what's wrong with using the pinion gear that has been provided with kit transmissions for the last two years? They're a standard pitch and pressure angle, so even if you're using your own gear train, you should be able to interface those pinions with it easily.
--Madison--
Unread 03-04-2006, 18:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Hex Couplers
4 of the AndyMark single speed gearboxes wouldn't be a bad choice either, nor would Dewalt transmissions.
Unread 03-04-2006, 20:49
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Hex Couplers
I'm going to second Sanddrag on using Dewalt gearboxes in a holonomic drive. They are very compact, reliable, relatively easy to mount and will give you a good speed to drive at. A bonus is that they're shiftable on the fly too. I'm a little worried from your picture that you're currently geared too fast. I can't tell the ratio exactly but a single geardown from a CIM usually isn't enough. You're definitely on the right track. Keep with your design and it looks like you should have a nice holonomic set up.
Team Website
I cant get my program into a hex file Serge Programming 8 17-02-2006 03:28
PIC16F84 -> Problem converting ASM to Hex Ballam Programming 8 18-11-2005 14:12
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
