Go to Post I found the best way to slice through pit crowds is to carry a clipboard and look like you know where you are going. People just seem to slide out of your way. :) - Ian Curtis [more]
Unread 06-04-2006, 14:18
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
ATMEGA16 PWM
Ok so here is my problem,
I have a AVR ATMEGA16 uC made by atmel. I have normal timers working but I cannot figure out from the data sheet how to get a PWM output. I have posted on avrfreaks.net but none will post an example code for me. All they do is redirect me to ode that is not for my uC. So i decided since I know a few people on here use them if they could post some very basic example code for me which just includes basic PWM timer operation and to have to code commented so I can look at it and learn from it.
The datasheet can be found at:
http://www.atmel.com/dyn/resources/p...ts/doc2466.pdf
thank you in advanced,
John
reading hobby PWM sciguy125 Programming 2 17-10-2005 20:47
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
