Go to Post ...thinking and learning never go out of style. - Rick TYler [more]
Unread 08-04-2006, 21:07
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Do Channels Matter?
Today I built a holonomic drive train, as can be viewed here, www.vexrobotics.blogspot.com . As can be read from my description, i Programmed Channel Six to be like Channel 4, just the opposite. Why did the robot move much much faster when the button was pressed, as opposed to when the joystick was at full throtle.
VEX Robotics Blog
Unread 08-04-2006, 22:42
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
Re: Do Channels Matter?
could you copy the code into here so I could see it?
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 09-04-2006, 01:06
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
The buttons output full forward or full reverse when pressed (255 or 0). If this number is fed directly to the motors, it would be full speed, but pushing the joystick full forward should do the same thing. Try checking the trim on the joysticks to make sure they're not off right now.
Unread 09-04-2006, 02:02
YonZ's Avatar
YonZ YonZ is offline
Team Role: Leadership
YonZ has a spectacular aura aboutYonZ has a spectacular aura about
Yeah I was the one who was there and found that out. We didn't look over the code yet, but I bet Bix did code it at full. I just pressed the back button accidentally and the thing began speeding along at full throttle, almost twice the speed that the bot was running at with joystick in full position.
Team 694
  • 2006- NYC Regional Website Award / NYC Regional Creativity Award / NYC Regional Finalists
  • 2005- NYC Regional Chairman's Award / NYC Regional Control Award / NYC Regional Semifinalists / Championship Galileo Division Semifinalists
  • 2004- NYC Regional Entrepreneurship Award / NYC Regional Quarterfinalists
Unread 09-04-2006, 07:41
gdo's Avatar
gdo gdo is offline
AKA: Patrick
check the RX ports, we had a problem similar to this were the channels were set for "RX 3" which drives it, but not full strength.
Unread 09-04-2006, 16:49
irishninja's Avatar
AKA: Nathan Bixler
I set the RX port to 1, should it be on auto? And I did program it at full speed. I just used a four motor tank on the right, and a four motor arcade on the left joystick, but one was on channel three, the other on channel six. Did that make sense? Probably not. I programmed it at full speed.
VEX Robotics Blog
Unread 09-04-2006, 20:56
gdo's Avatar
gdo gdo is offline
AKA: Patrick
if post the code, all will be answered, I can't really figure anything out from without the code
Unread 10-04-2006, 14:54
GlennGraham's Avatar
GlennGraham GlennGraham is offline
AKA: Glenn Graham
FLL #0006 (Shark Bait!)
Team Role: Coach
GlennGraham is an unknown quantity at this point
It may have to do with the way the channel values are mixed to give the desired motion. I believe there is a transmitter option for mixing as well as mixing done in software. Rather than use their "canned" tank or arcade methods, I would write my own code to read the raw values from the transmitter, map the values, and then send the values to the motors. A few print statements in the code to show the values recieved from the transmitter and the values you are sending to the motors may help point you to the source of the problem.
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
How to raise money for championship in a matter of weeks jrmarenda Fundraising 11 29-03-2006 22:42
Switching Channels Fred Agnir Control System 5 20-01-2006 20:54
Split topic - How many channels can the current (2004) Oi's and Rc's Handle? Elgin Clock Control System 6 02-01-2005 14:02
Does it really matter? archiver 2000 4 23-06-2002 22:40
