Go to Post [Programming a swerve drive] It's really really simple, unless you actually do it. - Ether [more]
Unread 09-04-2006, 20:11
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: Two Story Pit Area?
Originally Posted by SamS0Fa33O
Why not just find a place at a regional where thier is a 2 story bulding? Then just have spots reserved for teams on both stories.... seems like that is a safe plan!
The only problem with that is that you'll have about 5 teams all trying to use the freight elevator at the same time because they're all late for a match.
I think the 4 story pit is a really good idea (safety concerns, logistics, rules, feasibility, and cost aside of course). Anyone hear of the "elevator" they're attempting to make to the moon? Just use one of those. 5000 story pit area!
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 09-04-2006, 17:31
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Originally Posted by Qbranch
Hey, on the note of OSHA:
While I was buying some parts for a robot I'm building for fun, I ran across the electrical specs for that red main battery connector FIRST uses. Did you know its only rated for 50 amps?!
That means that there is a 120 amp breaker behind a 50 amp connector...
anyone else thinking this is stupid and is a safety/fire hazard?
This has been noted before. The basis for using a connector that is seemingly underrated is that, in 2 minutes, 120 amps could not compromise the connector. The key here is the time factor. If matches where significantly longer, then a lot of rules surrounding electrical safety might have to change.
In fact, if you looked at the average amount of current pulled over the whole two minutes, I bet it would be under 50 amps.
The connector is capable of carrying much higher currents over a 2 minute time span then it's rating would otherwise suggest. There is no danger from a properly cared for connector. You can use higher rated connectors if you wish, assuming rules don't change, as long as inspectors are satisfied that they meet all the requirements that the kit Anderson meets.
-Andy A.
Unread 09-04-2006, 19:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Right now, the rules don't actually allow for a more robust solution, even if you wanted one. See <R57>, which states that "[t]he Battery must use the Anderson Connector", meaning the red SB50.
As for the 2-story pit area, I'm wondering whether a team would actually go to the trouble of getting a structural engineer's stamp on their pit area blueprints, and then having it verified for proper construction once it was assembled. For liability reasons, I can't see FIRST ever allowing anything less than that, even notwithstanding the item in the manual which clearly prohibits these sorts of things.
Unread 09-04-2006, 19:19
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Team Role: Teacher
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
We thought about making a second story lounge and an area for the pit crew to take a load off of their feet. But, the sheer logistics of easily being able to set it up are mind boggling and well, it wouldn't be worth it. Plus, its not legal. But hey, we all can dream of a lounge area....
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 09-04-2006, 19:42
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Team Role: Teacher
Rookie Year: 2000
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
How about at IRI where the FIRST rules are a little more, well, flexible!
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 09-04-2006, 19:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Good idea, but I'm quickly coming to realize the cost to build such a structure would be in the thousands.
But I was thinking something. The footprint space it takes for a person to stand is not even as large as for an FRC robot. So it could be a people An 8 foot stroke pneumatic cylinder. It would be perfect. Like a 4 inch bore clylinder running at 120 psi.
Unread 09-04-2006, 20:22
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
Aha, I completely misread your initial post, David!
I thought that you were referring to a massive, pit-area-wide structure that would have multiple floors to accomodate extra teams and work/practice/shop spaces (I think I mentally deleted the 10x10 blurb). This, in and of itself, would be very cool and might allow venues with relatively cramped pit spaces to open up a bit and allow the full 10x10 footprint dimensions, if not more. Obviously, the overall height of the arena and the lighting of each space would be issues to tango with.
As for individual pits, I'd be worried about either having kids fall out of the upper levels or, if you have workspace on the upper level(s), having materials/sparks/nuts and bolts either fall through the floor or hit passers-by. We might have to start telling kids to keep their saftey glasses over their eyes on the field and on their foreheads in the pits.
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
Unread 10-04-2006, 00:06
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
These sorts of things are common in the trade show world, although not usually in sizes that small. I should warn you, though, that the last time I designed a trade show exhibit our 20x20 booth (only one story) cost more than $50,000, and we rented most of it.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 16-04-2006, 23:50
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
I had always dreamed of a 2 story pit, I believe a team did it this year out of painters scaffolding.
Hows my searching? Call 1-800-Green-Dots
Unread 09-04-2006, 20:07
Kyle Love's Avatar
Team Role: Teacher
but remember, the pits are almost half the size, wait a minute.....even more of a challenge!
Kyle Love
Teams I've been on:
Unread 22-04-2006, 23:17
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Let me think about it for one second.
OK, I am done thinking about it.
How about "NO!".
We are flexible, but not that flexible.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 22-04-2006, 23:47
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
FRC #0662 (Rocky Mountain Robotics)
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Hmmm. Come to think of it, one of the main reasons people are thinking a two story pit would be cool is because of the comfy space.
So perhaps FIRST could just put this into their site agenda and avoid the saftey hazard of teams trying?
Think the Autodesk Couch area at nats, but at every regional, and bigger there's just enough room if they move some of the arena chairs around...
I mean regionals are getting to the size where getting comfy seats should become a priority. If they put said comfy sofa area in the stands behind the pits, they'd avoid spectator squaters, meaning a cool hangout place to stratigize and stuff. But where would they get the couches? I can just see the agenda now, "be sure that your team brings a sofa to relax with".
But seriously, scouts and such work their butts off, is a nice place to relax for a few minutes too much to ask?
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 09-04-2006, 20:41
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
you have time to lounge?!
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 09-04-2006, 21:16
pez1959's Avatar
pez1959 pez1959 is offline
Cap'n Patty
AKA: Patrick
FRC #1959 (Aye Aye Robot)
pez1959 is on a distinguished road
Send a message via AIM to pez1959 Send a message via MSN to pez1959 Send a message via Yahoo to pez1959
I think if a team were to have this multi story pit it would cause one big problem. The problem simply being that if there was a multi level pit, no work would get done in my one table toolbox pit. We'd all be over there trying to get past the bouncer into yer lounge, which would then result in us taking a crate into our first match :-p
  #15   Spotlight this post!
Unread 09-04-2006, 22:46
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
You can dream about this, but won't ever do it. Kyle failed to mention the part when his team mentors said "no way".
A 2-story pit at a FIRST event is a safety hazard. It will cause more negative attention from facility administrators, insurance lawyers and safety personnel not familiar with FIRST. We don't need more of these people nosing around the pits.
This is NOT a good idea. Please, people, don't try to develop 2 story pits or push FIRST to allow them. The attention we will get won't be good.
Andy B.
Camera Confidence in the Portland Regional Pit Area Keith Watson Programming 1 03-03-2006 12:46
Construction of pit area Macdaddy549 General Forum 1 16-07-2005 15:20
Camera found in Curie pit area Lloyd Burns Championship Event 2 30-04-2003 08:59
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
Crates in pit area mnkysp6353 General Forum 10 25-01-2002 06:22
