Thread Tools |
Rating:
Display Modes |
Potentiometer 5 or 6 detents
Hey everyone!
I'm currently looking for a potentiometer(that you can wire onto the robot controller) that has at least 5 or 6 detents that can click into those positions. Does any body have any recommendations to where we can purchase these potentiometers? Let us know Thanks! |
Re: Potentiometer 5 or 6 detents
What are you trying to use it for? You might want to be careful if you're using a pot for anything relatively large, it may be hard to calibrate and to prevent from breaking. We attempted to put a pot on a rotation table to limit it's rotation to 180 degrees at one point, but a faulty autonomous program would have none of that! You may want to consider using rotary encoders or some other means of measurement.
I dont think Ive ever seen a stand-alone pot that had position detents. I have seen pots with knob designs that used detents - but I think they were custom designed for the application
ie, use an off the shelf pot, but make your own knob or level with click-stops where you want them to be. |
We want to use it to select autonomous modes. Anything under 12 detents will work. We are just having trouble actually finding any. I know some of you have used these... a part number would be great! Thanks!
If you don't have too many autonomous programs you could use a series of switches as a binary selector. You'd only need 5 bits (5 inputs out of the 4 ports) to cover the 12 modes you seem to need and more. |
We found one on digikey, but it doesnt have a shaft (to accept a knob) and is rather small at only 16mm wide.
Thanks for the help, we will keep looking. I am sure they are out there. |
If you look around page 1433 of the digikey catalog (which I totally knew off the top of my head), you'll find a type of switch that might be better for your application. It's called a rotary switch, and they come in all kinds of configurations, including SP6T. You can solder a bunch of resistors around the terminals, and it will behave exactly how you described, and can look like a pot to the OI or RC.
Yeah, what Kris said. The TechnoKats used a many-position rotary switch with resistors between each contact as an automode selector on the KatsKlaw OI in 2004.
forgive my ignorance of this years OI, is the red LED display still able to display user selected numbers?
set your code to read a joystick or pushbutton input - everytime you push the button increment a counter, and display it on the OI LED numeric output - that is your autom mode number you could have up to 256 different auton modes that way. |
#10
The rotary switch seems like a good solution, if it does in fact have solid feeling stops, so we could easily differentiate between the 6 positions.
The only problem is, I would be the one wiring it up and have practically zero electronics knowledge and would need some help selecting resistors and wiring it up to specific pins on the switch and the RC. If you guys could help me out there, It would be HUGELY appreciated. |
#11
----- Rc ----- Rswitch <--the dashes are just spacers here... 5V--^v^v--|--^v^v--gnd ________Input Rc=R, Rswitch=#R I=(5V)/(Rc+Rswitch) Vinput=I(Rswitch)=(5V)(#R)/(R+#R)=(5V)(#)/(1+#) Hope this helps. Last edited by Adam Shapiro : 11-04-2006 at 23:18. |
#12
For a six-position rotary switch, I'd use six 15k resistors wired like this: Code:
+5 <----/\/\/--*--/\/\/--*--/\/\/--*--/\/\/--*--/\/\/--*--/\/\/--*
OI |
analog input <-----------'
What you'll get from this is the equivalent of a joystick with six discrete resistance values: 15k, 30k, 45k, 60k, 75k, and 90k. You should use a dashboard program to determine what the actual numbers end up being, and choose appropriate ranges in the software to decide which of the six positions is chosen. |
#14
Edit: Kris beat me to it by a few minutes. And with impressive knowledge of the Digikey catalog!
One way to get approximately what you want is to wire up a SP6T switch as follows: +5V connected to a resistor R, then to the common lead. Signal wire should be joined to common lead. Lead 1: straight to GND Lead 2: thru resistor value R/4 to GND Lead 3: thru resistor value 2R/3 to GND Lead 4: thru resistor value 3R/2 to GND Lead 5: thru resistor value 4R to GND Lead 6: thru BIG resistor to GND This sets up a 6-setting voltage divider which will give the following voltages across the common resistors: Position 1: ~0V Position 2: 1V Position 3: 2V Position 4: 3V Position 5: 4V Position 6: 5V You can set up ranges in the program to check for this. These resistor ratios can all be approximate, but that gives you the widest separation possible for the analog input, reducing the risk of mistaking one mode from another. Of course, binary inputs are simpler if you have enough pins. Last edited by ZZII 527 : 11-04-2006 at 20:49. |
#15
See Kris Verdeyen and eugenebrooks posts in this thread for a solution on the OI that doesn't require any additional hardware. http://www.chiefdelphi.com/forums/sh...ad.php?t=44662
| Best source for a potentiometer? | railerobotics | Electrical | 20 | 28-11-2007 22:24 |
| Confused about potentiometer values | Kirk | Technical Discussion | 4 | 11-03-2006 16:29 |
| Potentiometer help | Unholy | Programming | 4 | 07-02-2006 17:48 |
| Potentiometer Help! | thoughtful | Programming | 4 | 18-02-2005 08:21 |
| Potentiometer | Joshua May | Technical Discussion | 8 | 22-05-2004 19:51 |
