Combining camera + encoder code
Hey all!
I took the camera.c, camera.h, tracking.h, etc.. and put it right into the encoder code that kevin watson designed earlier in the year. I did some slight modification to the code so that the camera doesn't use the servos to move, it uses the drive train to move around. I tested all the code in the normal camera version of the code, and it works flawlessly. Now when I took the encoder version of the code and combined it with all the files that Kevin Watson specified to include in the code written in camera_readme.txt, serial_ports_readme.txt, and tracking_readme.txt. I have everything the readme ask for. The code builds, the encoders work, but the camera says that there is No Camera Found!!!!!!! Any ideas!??!?! Thanks! ![]() |
Re: Combining camera + encoder code
are you handling the camera interrupts in user_routines_fast.c?
Yes I am
.. Could it be that I called the get or put data after the startup of the serial ports? Who knows.. Ill try some other stuff at the practice field today.. talk to yall soon |
The encoder version of serial_ports.c sets serial port 2 (the TTL serial port) to 9600 bps while the camera version sets it to 115200.
Which one are you using? It should be the one from the camera. |
Oh! Yeah i just found SPBRG2 = BAUD_9600; // baud rate generator register [251]
Was that what you meant? [edit] Yep i found it inside the code now.. Ill replace it and test all of it tomorrow ![]() Thanks everyone! [/edit] Last edited by kiettyyyy : 13-04-2006 at 01:03. |
Or just copy the entire file from the camera project. |
| Out of the Box Camera Code | russell | Programming | 9 | 21-10-2009 05:28 |
| Combining ADC, Serial, and Camera_s codes | kaszeta | Programming | 6 | 22-01-2006 20:23 |
| Camera Code | Fishdude404 | Programming | 1 | 25-01-2005 18:59 |
| Updated Encoder Code Available | Kevin Watson | Programming | 2 | 04-01-2005 01:00 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
