Go to Post don't be grumpy. No one is allowed to be grumpy during build. - JaneYoung [more]
Unread 12-04-2006, 23:36
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Build a PVR
Has anyone built their own PVR? I'm about to start piecing together my own. Here's what it will have:
Athlon 1.2GHz
MSI mobo
512 PC2100 RAM
120GB HD
Hauppauge PVR-150
Coolermaster case
GeForce2 video card (for the TV out only)
The best part is I only have to get the case and tuner card, everything else I'm piecing together from older PCs and getting from friends.
My questions for anyone who has done their own:
What software setup do you use?
What tuner card(s) do you use?
What case do you use if you have it in an entertainment center?
What video card, if any do you use or recommend?
I didn't think I would need anything that powerful since all it's doing is converting the video signal into the right format to display on the TV.
And generally what are your experiences with them?
I'm probably going to start off using Windows with GBPVR since that seems easy to setup and use. Maybe once I'm confident that all the hardware will play nice with each other, I'll try KnoppMyth. I'm not that confident with my Linux abilities and don't want to deal with all the stuff Linux puts you through, although I've heard KnoppMyth is very easy.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Where do you actually build your robot and who does the building??? Elgin Clock General Forum 47 14-11-2006 17:50
Who should build the field? Rich Wong General Forum 17 08-03-2006 17:38
Build Error S.O.S. TimeOut Programming 2 10-02-2006 00:10
OCCRA Teams - where do you build? Phil 33 OCCRA 7 28-10-2004 21:41
Build season wrap up Ryan Albright General Forum 2 24-02-2004 23:17
