Go to Post Ohhh Chiefdelphi how I love you and your 700 posts about a picture of a fish. - Boydean [more]
Unread 15-04-2006, 16:09
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: pic: kiwi vex robot
Originally Posted by Steve0100
Very nice design!
I've added sensors and have devised a scheme (still in the process of Implementation ) to have the robot detect walls and "bounce" off them before hitting with an angle of reflection equal to that of the angle of incidence. I'd like to put it inside a boxed-in area and have it bounce around like an billiard ball for robotics demos.
Thanks.
I really like how clean your assembly looks!
On sensors.... from my experience with the the Vex Ultrasonics.
They do a good job of sensing objects directly in front as long as object has a surface that is perpendicular to the sensor. In other words, when approaching a wall at an angle, the sensor wont pick it up very well at all.
Additionally, if you do put your bot in a box, the walls will bounce the 40KHz signal pulses quite a bit, causing misreadings from the controller.
Here's a thought. Try using the light sensors from the Line Following kit. With a little experimentation, you should be able to fine tune an algorithm to detect the relative distance from the wall based on the amount of light being reflected off of it. The biggest problem you will face with that is consistent light levels, and that may render this option useless. (Remember the difficulties with the CMU cam. and reflected light in 2005?)
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 15-04-2006, 17:05
Steve0100's Avatar
Steve0100 Steve0100 is offline
Steve0100
Steve0100 is on a distinguished road
Originally Posted by billbo911
Thanks.
Thanks, and thanks for the sensor feedback. I did consider Ultasonics, but couldn't hit on a scheme I thought would be reliable. Your info on the ultrasonics and performance at oblique angle confirms that I would have had a lot of problems. So- I'm using IR, very close proximity sensors, and a timing algorithm to detect differences in IR triggering in relation to angle of approach. I also have a mechanical switch backup plan- but I'd rather keep it clean with no real contact with the walls.
Thanks again for your reply. Billbo and Colin, your designs are both inspirational. Colin- I'll put your method of joining chassis parts with bearing blocks in my mental toolkit- I'm new to vex so I appreciate seeing new uses for the parts. It's amazing what can be done with, and learned from from, common creative constraints.
I'm glad I'm contending with 4-wheel math for holonomics rather than 3 though- much simpler. Thanks, trig.
Using WPILib on a Vex robot koenig3456 Programming 2 02-05-2006 14:56
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
