Go to Post Ineveitably what we do just might end up in the hands of millions of people. - JoeXIII'007 [more]
Unread 14-04-2006, 19:56
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
6WD?
Is there any way to get 6 motors (direct drive to 6 wheels) to get programmed and all?
I added a motor to each wheel and wondering what i can do.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 14-04-2006, 20:26
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Re: 6WD?
Assuming you are using easyC, could control it with tank drive by placing the "tank four motor block" and adding two "Motor Module RX" blocks for the fifth and sixth motors. All you have to do is make sure you assign one to the left and one to the right joystick.
Although I have no robot to test this idea on with me, one could possibly make a six-wheel arcade work by using the "arcade four motor" AND an "arcade 2 motor" in the same program. If you feel luck, maybe you could give it a try .
Oh, and of course, make sure its all in a while loop (I've made that mistake about 50 times).
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 14-04-2006, 20:27
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Re: 6WD?
You could have a four wheel and a two wheel arcade/tank running on the same channels.
VEX Robotics Blog
Unread 14-04-2006, 20:30
FRC #1405
Team Role: Coach
Re: 6WD?
Also i have no money to purchase the programming kit. Talking to others it sounds pretty impossible to do what i see with out the kit.
Unread 14-04-2006, 21:09
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Re: 6WD?
if you can find a radio shack that still has one, you can probably pick up a programming kit for $50. failing that how about making up a pwm y cable to feed the signal from a single port to two motors.
Unread 15-04-2006, 07:34
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: 6WD?
Be careful using pwm wye cables to drive two motors. The vex motor ports are only rated for one amp. The programming kits are on sale again, through June 3, for $49.99 many stores still have them in stock.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 16-04-2006, 18:21
Re: 6WD?
so, how about you just share signal and ground, but pull power off of one of the free motor ports.
Unread 16-04-2006, 20:08
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
Re: 6WD?
Yes that should work if you want to modify some pwm cables. Without knowing exactly how the motor ports are output. I'd check with Ricky Torrence at vexlabs just to make sure.
Unread 17-04-2006, 15:55
Re: 6WD?
you've got signal next to the labels, (white wire), 7.6v in the middle, (orange wire), and ground out at the edge, (black wire). use jameco 157382CK 3 pin housing with 157382CK female pins and 145357CK male pins. the housings aren't polarized, but the worst you can do is swap signal and ground.
Unread 14-04-2006, 21:04
syraweb's Avatar
syraweb syraweb is offline
Coach/Mentor
FTC #0001 (Team Unlimited)
syraweb has a spectacular aura aboutsyraweb has a spectacular aura aboutsyraweb has a spectacular aura about
Re: 6WD?
Four motors can be used to drive 6 wheels - either through a gear train or sprockets and chains. For the spring 2005 demo competition, the easyC programming system was not available yet, so our team built a 6WD robot in that way. It worked well with the default code. Check the photos and diagrams on our website - http://eaglevex.syraweb.org/TeamActivities13.htm.
Unread 16-04-2006, 13:51
FRC #1405
Team Role: Coach
Re: 6WD?
WOW! Thanks a lot for that!
Now here comes the big question, what did yo need to make that? On the Vex Lab site is shows that you need like 1 starter kit, 1 wheel kit and so on for the specific bots they make.
I do have the kit, wheel kit, gear kit, chain kit. no metal kit or programming kit yet.
Also, how did you lower the center motor/wheel?
I am very interested in making this on my own!
Unread 16-04-2006, 20:14
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
Re: 6WD?
If you're using the long angle rails in the starter kit for your frame, the holes are elongated just enough to give you about 1/8" offset if you keep the outer wheels tight to the top of the slot and keep the center drive tight to the bottom of the slots. If you want more offset use a combination of flat bearings and the "pillow block" style block bearing.
Unread 16-04-2006, 21:12
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
Re: 6WD?
nice bot, I think I could help out if you wanted
I added you in AIM hope to talk with you there
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 17-04-2006, 16:45
ICE MAN's Avatar
ICE MAN ICE MAN is offline
ICE MAN
AKA: John Cory Brown
FRC #0832 (Chimera)
ICE MAN is an unknown quantity at this point
Send a message via AIM to ICE MAN
Re: 6WD?
Now are you talking FRC or vex? if you are talking about first then you can use as many speed controllers as you need just as long as you don't exceed the $8000 budget, but there might be some rule about the maximum amount of victors that are allowed though I have never heard of it. If you are talking about vex, well then I know nothing to in depth, but I did hear a complaint about how many available inputs to the vex controller. if there is a limited amount of inputs for the vex controller then you might have to cut down on the number of motors/applications you are trying to use. you might be able to control two motors through one input, but I have no clue how to do this. Hope this helps.
In life, if what we want and what we get isnt what we expected, then thats life, because we cant always get what we want and what we get is never what we expected.
This is our teams offical website, enjoy:http://www.angelfire.com/droid/roswellrobotics/
  #15   Spotlight this post!
Unread 17-04-2006, 22:10
b-rant's Avatar
b-rant b-rant is offline
AKA: Brantley Brokaw
FRC #0364 (TEAM FUSION!!)
Team Role: Leadership
b-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the roughb-rant is a jewel in the rough
Send a message via AIM to b-rant
Re: 6WD?
i just built a six wheel drive with just two servos and it's pretty strong (it climbed onto a 3 ft. table at a 45 degree angle) but anyway i might post a picture of it tomarrow when i'm working on it in class i need to attach an arm to pick up a tennis ball so we'll see how that goes
Collaborations hayakuneko General Forum 46 29-03-2006 11:37
Questions about first time trying 6WD. Darkswordsmith Technical Discussion 15 18-02-2006 21:21
4wd vs 6wd? Yov Technical Discussion 22 06-01-2005 00:09
confirmed... 6WD recommendation of Joe J.. archiver 2001 0 23-06-2002 23:20
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
