Go to Post I happen to know that there is a back-order status from Exide. Seems for some reason people are ordering this product - Mike Martus [more]
Unread 27-04-2006, 20:49
DonRotolo's Avatar
Back to humble
FRC #0832
Thumbs up Maxbotix Sonar Sensor
After reviewing the specs on the Maxbotix Sonar Sensor, I placed my order. $30 + shipping, I can't wait for it to show up (It'll be here tomorrow!).
Bob from Maxbotix made a post here but I don't believe there were many views.
The short version is that they sell a small (<<1" cube) inexpensive (<$30) sonar sensor that measures from 6* to 254 inches (21 feet!) in one inch increments - and has three outputs: Analog voltage, Serial data, and pulse width. Takes up to 20 reading per second at full speed, or can be easily throttled back.
*Also senses from 0 to 6", but reports 6" and never less.
I will certainly be investigating this sensor over the summer. IF we had only had such a sensor (and the code to utilize it), we might have been able to avoid the defensebot that bumped us, causing us to flip ourselves on the ramp instead of blocking Team 11, and we might be at nationals with 16 and 95 instead of home...
I urge anyone looking to incorporate range data into a design to check into it. Once I get it working on my Vex bot, I'll file another report.
Don
SONAR Sensor Software Driver MikeDubreuil Programming 55 08-03-2008 11:03
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Help with sonar sensor supertw Electrical 3 24-01-2006 23:41
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
