Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 30-04-2006, 17:10
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Ultrasonic Distances
What is the analog number for 1 foot for the ultrasonic sensor?
VEX Robotics Blog
Unread 30-04-2006, 20:25
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Re: Ultrasonic Distances
the ultrasonic sensor does not return an analog value. it returns the time it takes sound to make a round trip out from the sensor to whatever's out there and back to the sensor. the distance can be had by multiplying that time by the speed of sound through air. you need to know the scale of the units returned by the routine that reads the sensor. microseconds, milliseconds, whatever.
or you can put something a foot in front of the sensor and see what kind of reading you get. note that there will be a little jitter, so you'll want to average a couple of different readings and then rather than comparing future readings to the value you get, check to see if they're close. for instance...
if ((new_reading >( one_foot - fudge_factor)) and (new_reading < (one_foot + fudge_factor))) {...
or you could wait for a reply from someone who's used easyC
Vex Ultrasonic Sensor not responding SomeoneKnows Programming 6 18-12-2007 16:48
VEX Ultrasonic Sensor delay P1h3r1e3d13 Programming 4 28-03-2006 13:45
Radio Control and Ultrasonic Sensor jeffmorris FIRST Tech Challenge 3 25-03-2006 11:06
Vex navigation with ultrasonic and encoders GlennGraham Electrical 4 13-01-2006 12:58
Using and Coding an ultrasonic sensor Jaine Perotti General Forum 14 06-08-2004 14:13
