Go to Post Welcome to The 2018 FIRST Robotics Competition: Bureaucracy Bash! - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 03-05-2006, 01:24
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: Why didn't your team use the Kitbot frame in 2006?
The kitbot frame could be improved (we collapsed parts of it this year just from our conveyor belt to pick up balls), and is impracitcal for some drive systems. I think building our own chassis would be interesting; however with no machining or even welding capabilities, our team is quite happy to get the kit frame than trying to invent something of our own with nothing but hand tools like we've had to do in the past (I think we might have managed to get someone to do a tiny bit of welding for us). The kitbot works very well, and unless you're a team who knows what they're doing, I think it's the best way to go.
Of course I'd just love to do a fiberglass or wood frame and be totally custom, but I'll stick with what we can do for now.
Unread 03-05-2006, 01:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I see building a custom frame as a great FRC pastime that so many new teams are missing out on.
Unread 03-05-2006, 07:41
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
We used the kit bot last year and it bent and racked.
My self and some of the other mentors knew we could do stronger and lighter with welded box. We took a ~13 lb kitbot and replaced it with a sub 2 lb box frame. We however have access to welders who weld thin wall tubing all day long.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 12-05-2006, 16:11
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Amen.
We've used a similar frame design, but built it out of Bosch extrusion for the simple reason that its simple to build off of and simple to use. Simple simple simple, gotta love it and hate it at the same time.
However, being next year is my senior year, I want to build something other than a boxy drivetrain. It's what we've been going with since 2000 something.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 02-05-2006, 22:04
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
Originally Posted by Billfred
I'd like to know from the teams that rolled their own frame why they chose to do so. Was it weight? Force of habit? The desire to do something different? Something else I've missed completely after being spoiled for two seasons by the Kitbot?
We have gradually welded more and more of our robot frame over the years, using 6061-T6 aluminum box tubing. It avoids the weight of the attaching hardware and avoids loose nuts and bolts. This has been so successful it appears that we will be upgrading to a higher current welder next year so that we can weld thicker aluminum sections with impunity.
Unread 30-05-2006, 23:31
twolf's Avatar
twolf twolf is offline
FRC #1336 (The Untouchables)
Team Role: Teacher
twolf is an unknown quantity at this point
We are also trying to look at moving away from the KOP chassis for next year, where do you suggest getting this particular type of box tubing and what is a typical cost?
"Pushing Back the Frontiers of Ignorance"
Unread 31-05-2006, 00:00
Team Role: Teacher
Here's our 2006 frame and here's our 2005 frame. Both made from 6063 aluminum box tubing (1/8" wall thickness) cut, machined, welded, and polished. Bought the box tubing from a local supplier. There are two online suppliers that come to mind where you can check the price.
www.onlinemetals.com
www.metalsdepot.com
Unread 13-05-2006, 20:46
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
The kitbot is great if you want to build a kitbot, but we wanted to build a 1139 bot. Building your own frame takes minimal effort, gives infinite flexibility and theres nothing stronger than a welded connection. Designing around the kitbot seems like more trouble than its worth.
1139 Alumni
Unread 13-05-2006, 22:22
Beth Sweet's Avatar
Beth Sweet Beth Sweet is offline
is getting lost in her new home
FRC #0116 (Epsilon Delta), #1504 (alum), #67 (alum)
Beth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond repute
This is going to sound really silly, but we didn't use it this year because we didn't have to. It was kind of like a right of passage, we can do what we want! Kind of a reward for doing so much better in getting sponsors this year
This season, I was a part of a great team, with great kids who were really inspired, and who inspired me back. That's my brag, what's yours?
Unread 14-05-2006, 00:29
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Our team did use the kitbot frame in 2006. But I sure wished we hadn't.
The problem with that frame is that it has no cross bracing to prevent bending. Over time it will slowly deform.
Which is what happened to us.
We started out with a six-wheeled, rocking (center wheel lowered), robot and ended our last match without any rock. The whole frame had literally been bent into an arch, with all six wheels flat on the floor.
To make matters worse the sides also bent in-wards! This distorted our chain path causing us to perpetually lose chains during matches.
I will be very hesitant to use the kitbot again in the future.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 14-05-2006, 00:39
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Very true... but to solve the problem why not make your own cross bracing to prevent it from bending?
... the kit chassis that is provided in the kit is very useful and I am sure many teams thank FIRST for providing them each year.
Unread 15-05-2006, 17:07
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
we dont use it because we have plenty of plate acces to a waterjet 4 welders and a cnc plasma cutter. although every year we begin by saying were going to use it because it would be so easy. then we go nuts and make it with the waterjet anyways.
Unread 15-05-2006, 18:37
run the trap!!!
And while I'm at it, why don't I make my own frame that's better?!
-Philip J. Fry
Please post your 2006 Chairman's Award entries nehalita Chairman's Award 3 22-03-2006 19:22
Thank you Team 179, team 237, team 269, team 303, team 1065, and team 1251 Arefin Bari Thanks and/or Congrats 13 16-03-2006 20:52
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
