Go to Post I'd rather have a target on my back than be invisible to the competition. - Chris is me [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 01-05-2006, 01:22
Billfred's Avatar
Billfred Billfred is offline
Why didn't your team use the Kitbot frame in 2006?
Alright, we've heard many folks talk about how generally awesome the Kitbot can be for teams. (I've said it quite a few times myself.)
I'd like to know from the teams that rolled their own frame why they chose to do so. Was it weight? Force of habit? The desire to do something different? Something else I've missed completely after being spoiled for two seasons by the Kitbot?
(Just as a note: I'm not saying one way or the other is better. I just want to know why the other side does things like they do. It makes life interesting.)
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 01-05-2006, 01:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Why didn't your team use the Kitbot frame in 2006?
The primary reason is that we can do better than the kit frame (and gearboxes) can provide us. Whether or not that gives us any advantage on the field, I believe it does good things for the skills of the students on our team. We built an incredibly robust and lightweight frame from aluminum box tubing. The way we had our wheels, pillow blocks, and chains setup would not have been possible with the kit frame. We were able to save space and weight by putting a lot of design and fabrication into our own custom frame (and drive system). Also, on a more personal level, I don't believe that all robots should look the same.
Unread 01-05-2006, 02:43
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
I guess we didn't because we've gotten used to the versatility of T-slot aluminum. We don't have in house welding capability so building a really good custom frame isn't possible. We did, however, use the kitbot frame as raw material for brackets and such.
Unread 01-05-2006, 08:56
JVGazeley JVGazeley is offline
Don't Walk... Do the Robot
AKA: Jason Clift-Jones
FRC #0759 (Systemetric)
JVGazeley is a jewel in the roughJVGazeley is a jewel in the roughJVGazeley is a jewel in the rough
Send a message via AIM to JVGazeley Send a message via Yahoo to JVGazeley
Traditionally, we don't even use aluminium. We prefer to build a frame out of steel. Easier for us for various reasons...
FRC: Team 759 Systemetric; Team Scrutineer '05 & '06, Safety Captain '06.
FLL: Cambridge (UK) Regional Helper '04 & '05, Bottisham Barnacles; Mentor '05
Unread 01-05-2006, 15:30
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
For the past two years my team has used the kitbot frame, simply for the convenience. Next year we are planning to make our own frame (or at least get the kitbot frame welded) because while it is sturdy, it is also VERY heavy. I have heard you can save 10 lbs or so by welding instead of using all those bolts.
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 02-05-2006, 19:07
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
We've used the kitbot frame the last two years, and I like it. However, I want to make a custom frame out of welded box aluminum next year to save a few pounds, and save space by designing to the size you need, not like the KitBot frame which is designed to be usable in many configurations. (ex. a two inch wide wheel well instead of 3" ish size. (Or is it four?)) Fiberglass make make an appearance too.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 02-05-2006, 19:28
DonRotolo's Avatar
Back to humble
FRC #0832
We didn't use because the T-slot aluminum seemed so good. We also saved a bunch of weight. It is hugely flexible (adjustable) for things that you don't know exactly where they're going to go.
BUT... our frame was not as impact resistant as with the kitbot we used last year. The T-slot fasteners don't handle shock that well. 20mm T-slot is not as bend-resistant as it seems.
For next year, we'll probably use the kitbot for the lower part of the frame, and T-slot for the upper part. Or maybe hand-laid fiberglass-epoxy. Or machine it out of a solid block of titanium...
Don
Unread 02-05-2006, 19:32
spears312's Avatar
spears312 spears312 is offline
El Capitan
AKA: Ryan
FRC #0312 (Heatwave)
Team Role: Leadership
spears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nicespears312 is just really nice
Send a message via AIM to spears312
With our swerve drive this year, a kit frame would have had to gone under heavy modification to fit our needs, and since Baxter provides us with an awesome machine shop (and Dawson, the best welder in the world), we went ahead with our own frame. I personally see nothing wrong with the kit frame, we did use it last year after we modified and welded the heck out of it and it withstood a lot of crushing impacts (most memorably a head on head full speed impact between us and SPAM last year at nationals) with little more than a few small dents. Given the opportunity though, I would almost always choose a custom frame mainly because you know you can engineer it how you want so that it fits your needs with out risking structural integrity.
For any team that wants to save some cash or doesn't have the capabilities to build their own frame, the kit one is really a good deal (especially when you strengthen it a bit).
HEATWAVE 312
2004 FL Regional Chairman's Award Winners
2005 UCF & Palmetto Team Spirit Award Winners
2005 Championship Curie Division Semi - Finnalists (thx to 118 and 229)
FIRST
Under Construction
Unread 02-05-2006, 20:27
Guy Chriqui Guy Chriqui is offline
AKA: Guy Chriqui
FRC #0004 (Element)
Guy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really nice
our team didn't use the kitbot this year because we knew like 696 that we could make a better one for ourselves. we used 2x1 aluminum 1/8 thick tubing and welded a frame (like 254, 60 etc) it is much easier to work with but requires the ability to machine. it worked out well for us and is extremely strong. also the most important feature is that when you finish you can powdercoat it and make it look really sharp because it doesnt matter if it runs well it just has to look good right?
-guy
team4element
Unread 02-05-2006, 21:31
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
There were two reasons-
1. We wanted to challenge ourselves with designing our own chassis
2. We managed to bend up the kitbot chassis in triple play, so we wanted something a bit more robust. We still managed to bend a few of our framerails. (1/4"x3" 6061 aluminum, with some speed holes)
Team 675-Alumni
Near Chaos Robotics
Unread 02-05-2006, 21:39
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Holonmic 4-wheel is really hard to do, let alone try to KitBot the fame. that was a big factor.
Unread 02-05-2006, 21:57
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
We used the kitbot all right--for testing. Makes big heavy shooter prototypes much easier to move around. We have pretty much always used our own frame. A good reason not to use kitbot: robot droppings, such as the bolts for the frame.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 02-05-2006, 22:01
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Kitbot and rivets don't mix well for us either.....
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Team Role: Teacher
Good point. Actually, we did too. We used the KOP frame and gearboxes to give the programmers something to work with before we had a real robot. They much enjoyed it.
  #15   Spotlight this post!
Unread 03-05-2006, 00:45
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
-guy
Actually, we did use a kitbot frame in competition this year. When our powder-coated robot decided to hang out in SoCal until Thurs night of the Greater Toronto Regional, we obtained a kitbot frame from the TechnoKats to build the "One-day Wonder". It was very easy to assemble, quite strong, and though not the most mass efficient chassis, it was quite acceptable. The predrilled holes for the axles (with the center wheel axle slightly lower than front and back) and transmissions makes assembling the drive components very straight forward. Next year, we'll have our "newbies" build a drive base from the KoP frame and transmissions so they can have a driveable 'bot early in the build season.
P.S. Guy says a good looking robot is better than one that is running well just to "jerk my chain". I guess I'm just not one of those "form-over-function" people.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Please post your 2006 Chairman's Award entries nehalita Chairman's Award 3 22-03-2006 19:22
Thank you Team 179, team 237, team 269, team 303, team 1065, and team 1251 Arefin Bari Thanks and/or Congrats 13 16-03-2006 20:52
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
