Go to Post Oh, for the love of cod, can't you see that Dave is messing with us just for the halibut? When the actual clue comes out, I'm sure we'll all be singing a different tuna. - Pat Fairbank [more]
Unread 02-05-2006, 16:48
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
camera on edu controller
I am trying to run kevins camera code on an frc edu controller, i have followed all the steps to set it up with the edu default code but when i run it the code crashes sometime before the default routine is able to run, does anyone know what the problem is, kevin if you have the code already added to the edu default code that would be awesome too.
Thanks,
Cuog
KK4KQO
http://voltair.us
Too many projects, too little time.
Unread 04-05-2006, 01:45
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: camera on edu controller
Thanks,
Cuog
http://kevin.org/frc/edu_camera.zip
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 06-05-2006, 20:28
Cuog's Avatar
AKA: Alex
FRC #0422
Thanks kevin now i can get to work
KK4KQO
http://voltair.us
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
porting camera code to 2005 bot controller dwc309 Programming 6 28-02-2006 19:16
Camera shows no love to drive motors anifinder Programming 4 13-02-2006 10:31
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
