Go to Post There are always going to be tough calls, and you just have to trust in your officials to do the right thing. - Jeff Waegelin [more]
Unread 02-05-2006, 20:19
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Problem solved but now another question
I'm tyring to compile the default code for the Vex microcontroller. Unfortunately, MPLab can't find some of the header files. The odd thing is that I included the header files into the project and they are in the same directory as the default code.
**Never mind. Some of the files are defined locally while some of the others aren't. That's why the error message is appearing.**
Is there any significance as to the why some files are defined locally and some are not? Can I just change that?
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 03-05-2006, 08:54
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Problem solved but now another question
You can just change that.
The compile process allows you to do this essentially to allow you to override the standard includes and substitute your own. It does lend itself to confusion if you don't realixze how it all links together.
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
