Go to Post The bottom line is, what works best for YOUR team is what the best solution is. - EricH [more]
View Poll Results: You think we will get them to use?
Yes 9 15.25%
No 38 64.41%
Maybe 12 20.34%
Voters: 59. You may not vote on this poll
Unread 04-05-2006, 23:43
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Re: New Speed Controllers :)
Originally Posted by Tom Bottiglieri
By the way, you would be much better off using thick stranded wire than one solid piece of wire. Current flows on the surface of a conductor, so the amount of current a single piece of wire can transmit is limited by its size.
Only the alternating component of electrical current tends to concentrate on the surface of a conductor. This is often called the skin effect. The effective depth to which current penetrates into the interior is inversely proportional to the square-root of the frequency at which the current alternates, so higher frequency current tends to concentrate on the surface, while dc is uniformly distributed over the cross-section of the conductor.
Since only a small component of the motor current in a FIRST robot is ac (due to the pulse-width modulation of the Victors), using stranded wire does not improve the current carrying capacity significantly over that of solid conductors with the same total cross section; i.e., the same AWG.
However, using stranded wire is still a good idea because it is less prone to damage from bending and flexing, and it forms better electrical connections when crimped to standard terminals.
Richard Wallace
since 2003
Unread 05-05-2006, 00:12
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Are these actually new? I was pretty sure the 885's have been out for a while now. Maybe I'm just confusing myself though.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 05-05-2006, 00:19
Billfred's Avatar
Billfred Billfred is offline
I can't place a date or anything, but I know that the 885s have been available since at least last off-season.
Unread 05-05-2006, 04:10
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
By the way I know that, it was sarcasm because to run 120A through 1 wire you would need 0 gauge wire. which is about 1/2" in daiamter.
I can't even Imagine trying to run wires like that to a motor.
Besides you can really draw more current then the wire already on the motor will allow(if any), like the CIMs with out modifying it. Or if there is no wire you would have to go by cantact area, and the other motors dont have a big contact area.
Unread 05-05-2006, 15:17
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
I really don't see these being used in FRC anytime soon, they're just too powerful. The price for a V885 is higher and the motors would be ungodly, an example of the type of motor these are for is the PERM PMG 132, it can pull 110A constant, it costs almost one thousand dollars! That is way to pricey for FIRST. Instead, I would also, like Gdeaver, like to see a little more computing in the 884. Maybe a just single, low-end PIC (although it might need shielding), some sort of sensing to keep you from frying it from wiring the inputs backwards, maybe a lower profile fan, and an improved PWM slot. (maybe like the old ones with just pins, then add a clip on the top to hold it in place) It could be the Victor 884-Xtreme (or 886), some cheap 20A speed controllers for the weaker motors would be nice too... (Maybe it's time for IFI to plunge into the Hobbyweight battle bot market with low current speed controllers, maybe name them the Rufus series)
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 05-05-2006, 18:43
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
I can't believe it's not already there. That would be a great improvement.
Like these?
I like that too. http://www.robotmarketplace.com/mark...e_ifi_esc.html
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 05-05-2006, 18:33
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Originally Posted by sparksandtabs
draining 120A continously will COMPLETELY drain your battery in 9 minutes flat. SO think about it if you have 2 motors (probally drive) running around 120. you battery will completey be drained in 4.5 minutes. Not to mention everything else your running. This means (estimate only) that by the end of the match your battery would be around 6-7 volts maybe. do you really wanna drain your batteries that fast? Besides doesn't that ruin them?
All this talk about draining batterys, don't you think maybe just maybe FIRST might hand out new batteries for next year b/c just like the field elements and some of the KOPs used they are old and we may just see some new stuff next year (Batteries, Control Systems, Motors and of course Field Elements) One could only hope =)
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 05-05-2006, 18:49
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
Having little electrical background [besides knowing that the inputs must be wired correctly or the thing will melt], this is my perspective on the use of these-
As promising as these look, there is a setback to them: the $200 price tag, [only] $85 more than an 884. Unless the KOP includes enough victors to control every motor properly, there will be teams that will be at more of a disadvantage. Also, the 120A continuous draw seems potentially dangerous in situations where mechanical systems malfunction [robot damage] and cause the motors to run near stall. To me, it seems like you have your either-or choices of:
1)Victor Meltdown [and another $200 down to replace it]
2)Motor burnout and the stench of Eau de Fisher Price for the rest of day
3)Battery damage from high current draw.
My vote goes to the 884. Cheaper and Safer.
_Alex
Unread 05-05-2006, 19:11
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
The speed controller's current rating is the maximum that it can withstand. The fact that it can take 120 A actually means that it's safer—but that's not really important, because it's the circuit breakers that determine what current will actually pass through the circuit.
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
