Go to Post the hardest task this year is the same as every other year: getting the engineers out of the crate so you can close it up and the FedEx guy can haul it away! - KenWittlief [more]
Unread 07-05-2006, 13:21
Robots_R_Us Robots_R_Us is offline
Robots_R_Us is an unknown quantity at this point
Vex Components For Other Robots
The Vex spocket and gear kit has plastic gears and chain....are these
Vex specific or are they sourced from a third party?
Also, has anyone reverse engineered the sensors to be able to use them
on other robot systems? In particular I am thinking of the ultrasonic,
rotational and light sensors.
Thanks
RRU
Unread 07-05-2006, 14:25
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Vex Components For Other Robots
Our team used the VEX ultrasonic sensor with great success on our FRC robot this year. I imagine nothing would prevent you from using any of the other VEX sensors, either.
Unread 07-05-2006, 14:44
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
The Easy-C gear tooth sensor functions work with the Vex encoder. The KOP gear box output shaft has a tapped hole in it. A thread by 1/8" square adapter can be made to allow the vex encoder to work with the KOP gear box.
Unread 07-05-2006, 15:08
When you says great success, what efforts needed to be done to handle the hardware/software differences?
RRU
Unread 07-05-2006, 15:15
Unsung FIRST Hero
RRU
I imagine that if you were using EasyC, almost nothing would have to be done different than on a VEX robot. However, we were using MPLAB, so it was simply a matter of writing an interrupt driven routine to measure when the echo came back from whatever we were pinging. It's identical to most other ultrasonic sensors, so you could read more about how to code for them elsewhere.
Unread 07-05-2006, 15:19
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
to interface these sensors with a different system you would just need to know how to program to receive the signals from them. The major difference is that instead of using mostly drag and drop software you are using bare bones C. But hey it can't be as bad as using ASM.....Can it?
Unread 08-05-2006, 00:18
CraigHickman
Posts: n/a
All the vex sensors will port over to other systems fairly easily. Our FRC bot this year lost a limit switch, and the only replacement we had was a vex switch... so we changed the wire (they're backwards) and put it on. No problems.
Unread 31-05-2006, 17:56
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
One of the teams in Israel used the vex bumpers as buttons on their OI.
I found that interesting...
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Combine Lego and Vex parts? jeffmorris FIRST Tech Challenge 3 25-02-2006 09:01
Help Brainstorm New VEX Robots for TV! InnovationFirst FIRST Tech Challenge 17 03-10-2005 12:27
VEX Robotics vexrobotics FIRST Tech Challenge 8 30-03-2005 23:25
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
