Re: Signature Size Enforcement
Thanks Brandon, it was getting out of hand.
Don |
Old-ish topic, I know, but I wanted to bring up something I noticed.
Normally, I use a PC with Mozilla Firefox, and the 200 px cutoff works fine. But here, a work, I use a mac with Safari, and I have noticed that Safari cuts off more than 200 pixels on people's signatures (or it cuts off more than Firefox does). I first noticed it when looking at Arefin's signature (which I guess is close to 200 px), and the very bottom of it is cut off when I am using Safari, but is entirely visible when using Firefox. Maybe this is a bug - if not, I can live with it, but if it's a problem I thought you might want to know. It might be related to the new feature that allows people to say what event they are attending underneath their signature (maybe one browser considers it a part of the signature, and the other doesn't?). I like the addition of the 200px display limit... makes reading the forums much easier. Thanks! |
The reason for the differences across browsers is in the way each handles the specifics of font sizing. The same CSS font size (from xx-large to xx-small, with default being medium) may have slightly different pixel counts between different browsers and platforms. Also, the spacing between lines is subject to browser defaults because the line-spacing attribute is not defined in ChiefDelphi's style sheet.
The reason this is all relevant is two-fold. First, it effects the actual size that the signature occupies. Second, the signature maximum height is not actually defined as 200px (pixels), but as 12.5em (which is approximately 200 pixels). An em unit size is a function of the text size, which as I mentioned can vary slightly. This is not a bug on Brandon's part, but an expected (although possibly undesirable) deviation. |
Yea good job guys, you guys rock!
Yea! Awesome! Excellent! Big signatures are really annoying. First post!! Yeah! Last edited by Booger : 12-07-2006 at 15:04. |
| Size Down Those Signatures! | Adam Richards | CD Forum Support | 26 | 09-05-2006 10:06 |
| About being overweight and exceeding your size requirements – the need for reinspecti | Godzilla! | General Forum | 48 | 28-03-2006 11:11 |
| Blob Size | d.courtney | Programming | 7 | 29-01-2006 20:48 |
| New signature rule. | Brandon Martus | Announcements | 2 | 25-09-2005 13:15 |
