Re: Gear Ratios
Ahh yes. I overlooked small parts inventory. I'll give motion industries a call also. Well thanks for your help. When I finally get one built, I'll post alot of pictures. Thanks again for everyones help.
Re: Gear Ratios
Well I think Mr.Needel and Sandrag answered your questions about the gear ratios, I would like to add an idea about your 8 ft of chain comment. I was wondering if you have ever seen how team 71 turns there crab modules it's really cool and is a much lighter and fool proof concept then chain and 71 uses it so you know it works. They use a type of window motor belt strapping it's a really strong plastic that is used in your automatic car windows. I would definitely pm someone on 71 about it or at least see if it would work for your application.
Trying to be helpful, Drew |
| 4WD, Tank treads and gear ratios. | Pipisongo | Technical Discussion | 4 | 07-09-2005 15:38 |
| How to calculate planetary gear ratios? | sanddrag | Technical Discussion | 2 | 27-02-2005 11:55 |
| Efficent number of Gear ratios... | Matt Attallah | Kit & Additional Hardware | 12 | 14-09-2004 10:42 |
| gear ratios | roboteer49 | Motors | 22 | 29-04-2004 20:51 |
| Gear Ratios | Joshua May | Kit & Additional Hardware | 4 | 01-02-2004 22:54 |
