Go to Post ... the team that *DOESN'T* design things in the offseason for prototyping and testing will always be at a much bigger disadvantage. - Cory [more]
Unread 13-05-2006, 15:11
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Easy OmniTrack
Well I was board so I made an OmniTrack in Alibre Designs. It uses square aluminum tubing as the frame. Then i drilled some wholes in it and welded a few connector pieces on it, put in the shaft, bushings, and roller and here it is. The roller isn't perfect, I know, so try to focus on the shape of it.
I'm an extreme "I want to make something" state.
ID:	4399  Click image for larger version
ID:	4400  Click image for larger version
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 13-05-2006, 15:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Easy OmniTrack
Do you have a design for the drive sprocket?
Unread 13-05-2006, 15:36
Joe_Widen's Avatar
Re: Easy OmniTrack
I'm thinking right now that I'll either make a custom drive shaft using hex stock or do the track as double wide and integrate an aluminum chain in there somehow. I'm leaning towards the hex stock idea. I think I'll will it with the roller imprints on it so its grabs the rollers as it turns. It'll be pretty tricky. Looking at it, If I used two wheels with high traction matierial on it and then put high traction matierial on the link's frame, it would work pretty well. The only problem would be alignment would need to be near perfect. I'll cad one up real quick in a bit.
Unread 13-05-2006, 15:43
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Easy OmniTrack
use a cylinder that the tracks will wrap around at each end and then make a spherical hole around it for the balls, and then just bore a hole in the center. You can use anyway to drive it, because it will just be like attaching a sprocket, spur gear or whatever to a normal wheel.
Unread 13-05-2006, 15:44
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
Team Role: Coach
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
Re: Easy OmniTrack
Just a quick question... is there an actual application you can think of for this? It seems to me to be heavier than normal track, and have less traction. It would help turning, I suppose, but at the expense of pushing forse, which is usually the purpose of a track. Is there something I'm missing here?
Oh, maybe I shouldn't have pushed that...
Unread 13-05-2006, 16:17
Joe_Widen's Avatar
Re: Easy OmniTrack
Heres a way to drive it.
The reason this is being made is because it offers all the advantages of tank treads and the advantage of holonomic drive (put them on 45's to each other). It doesnt have the disadvantages such as hard to turn and being easily pushed. The only disadvatage I can think of is that its more difficult to turn tank tread.
ID:	4402  Click image for larger version
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: Easy OmniTrack
Omnitrack is like omnidrive right? Move in all directions but with tracks. I dont know how that would work but good luck... I think.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 13-05-2006, 18:03
Skute327 Skute327 is offline
AKA: Alex Symington
FRC #0871 (Robotechs)
Skute327 has a spectacular aura aboutSkute327 has a spectacular aura about
Send a message via AIM to Skute327
Re: Easy OmniTrack
I had a simalar idea after competition this year after our omni wheels proved flimsy (I still have some parts)
I would really like to see this work, but my team cant afford to try
to drive, I would suspend the track betweeen two chains or belts
It would be much smoother insted of trying to drive a "square wheel"
it would also need support in the middle (difficult with indevidual links)
I would use sliders maybe delrin or something tough (and replaceable)
Hopefully next years game warrants using something like this
Unread 13-05-2006, 19:13
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Re: Easy OmniTrack
Ok, so I got a little inspired. (Modeled in Rhino 3d)
Team 675-Alumni
Near Chaos Robotics
Unread 13-05-2006, 19:53
Joe_Widen's Avatar
Re: Easy OmniTrack
Now thats just creative.
Unread 13-05-2006, 19:57
MikeJ675's Avatar
Near Chaos Robotics
AKA: Mike Jeffries
Re: Easy OmniTrack
For anyone having trouble visualizing what it would look like, I made this-
I love Rhino3D
You can fill in the guts yourself.
Team 675-Alumni
Near Chaos Robotics
Unread 13-05-2006, 23:33
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
Re: Easy OmniTrack
These Omnitracks(i preffer the mecanums tho) seem like an awesome idea but i feel that the use of them will be difficult, look at the cost of mecanum wheels to produce. People are talking about over 1000 dollars to machine. Then there is the weight issue for these, and how big will the drive wheels need to be, in this case i think that it will prove much more effective to go with standard mecanum wheels then these treads(but of course someone will likely prove me wrong now)
KK4KQO
http://voltair.us
Too many projects, too little time.
Unread 14-05-2006, 00:16
MikeJ675's Avatar
Near Chaos Robotics
AKA: Mike Jeffries
Re: Easy OmniTrack
hey, never said they were effective, cost especially. I just think they're freakin' cool.
Team 675-Alumni
Near Chaos Robotics
Unread 19-06-2007, 20:46
Joachim Joachim is offline
Joachim has a spectacular aura aboutJoachim has a spectacular aura aboutJoachim has a spectacular aura about
Re: Easy OmniTrack
Originally Posted by Cuog View Post
...People are talking about over 1000 dollars to machine. Then there is the weight issue for these, and how big will the drive wheels need to be, in this case i think that it will prove much more effective to go with standard mecanum wheels then these treads(but of course someone will likely prove me wrong now)
Clearance between the rollers and belt is only 1/8", but someone could maybe use these to make a less expensive(?) version:
angled roller belts from Interlox
  #15   Spotlight this post!
Unread 19-06-2007, 21:09
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: Easy OmniTrack
The similarity between both our designs is amazing. Great minds think alike?
http://www.chiefdelphi.com/forums/sh...ad.php?t=46501
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
pic: Omnitrack Summer Project? Gabe Technical Discussion 27 07-09-2006 00:28
Easy C Tutorials jbbjjbt Programming 3 21-02-2006 08:40
Easy C redragon226 Programming 8 28-01-2006 16:56
MPLab to Easy C sbwprotoss9 Programming 1 12-01-2006 22:00
easy game? JulieB General Forum 0 12-01-2005 09:29
