Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Unread 14-05-2006, 20:57
987HighRoller's Avatar
987HighRoller 987HighRoller is offline
Vegas....Baby
AKA: Alex Sambvani
FRC #0987 (High Rollers)
987HighRoller has a spectacular aura about987HighRoller has a spectacular aura about
Teams: How did you use your potentiometers this year?
Hi,
I was curious as to how teams that used potentiometers integrated them into their designs. Team 987 mounted our potentiometer on top of a pulley that controlled our shooter's turret. Using the values between 0 and 1024, we determined the position of our turret. Also, were there any teams that actually converted a potentiometer's value into a measure of degrees?
Team 987 - The High Rollers - Las Vegas, Nevada
2007 Las Vegas Regional Finalists
2007 Newton Champions
2007 Championship Winners! Thanks to 190 and 177
2008 IRI CHAMPS with 67 and 330
Unread 14-05-2006, 21:14
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Team Role: Mechanical
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: Teams: How did you use your potentiometers this year?
Last year our programers were able to use the pots to program movements into the robot by recording how much they moved and we could track our arm and had preset positions to load tetas and such
MechWarriors 573
Unread 14-05-2006, 21:16
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
Rookie Year: 1998
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
HOT used pots this year to control the turret's spinning motion.
I'm proud to be a...
Unread 14-05-2006, 21:17
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
We tried using a potentiometer to measure the angle at which our shooter was shooting at. We are still working on the code....
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
Unread 14-05-2006, 21:42
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
We used a potentiometer to measure the angle of our shooter.
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 14-05-2006, 22:15
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We used THREE pots to tune our PID loops.
run each one into an analog.
P = analog
I = analog
D= analog
Inside the software, they had to be mutliplied by 0.0001 I think...then the value of the pot was the P,I,D values. Made for a very fast tunable system. Used that in conjuntion with LABVIEW to graph the output...it worked out great.
I wish I could find a picture of the pots, but I can't. I do know our software is posted at frcsoft.com if you want to check out the software side of it. Once the tune was found, we hard coded the value into the software I think...I can't remember it's been too long...lol....
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 15-05-2006, 06:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
We used one (actually two, but the second was a backup) to measure the rotation of our shooter.
Unread 15-05-2006, 09:27
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Rookie Year: 1999
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Last year we used pots to read position on all three arm movements (height, left-right, angle) with corresponding pots on the OI for direct position control. Yes, we converted the values into degrees for the arm angle.
This year we used one pot in conjunction with two selector switches on the OI to adjust many values. I had hoped to implement storing these values in EEPROM, but never got that far. Still, setting the shooter speed and turret position PID loop values was easy. Once we found the values we wanted, we just hard coded those as defaults.
Unread 15-05-2006, 09:30
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Ours, like always, is on our motor that turns the independantly steered front wheel. We've dont that for the past 3 years. Infinitely better than tank steer. lol
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 15-05-2006, 21:31
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
P = analog
I = analog
D= analog
snip
I'm very curious as to what your PID loops controlled. Do I presume correctly turret position, launch angle, and ...
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 15-05-2006, 21:46
Controls Engineer
AKA: chakorules
Our programming team decided to use a PID control method to keep the lookup table values we had calculated offline in check with our robot system.
In order to use a PID implementation, we needed some sort of feedback device. The gear tooth sensor provided in the 2006 kit of parts was our feedback sensor of choice to measure the velocity of the wheel. The velocity set point we determined would have to come from the camera by mounting the camera on a tilt servo. While the camera was instructed to seek out the green color of the illuminated light, software controls kept the camera tilt servo field of view (FOV) in the center. Once we acquired a center of target, we then knew the servo tilt pulse-width-modulation (PWM) value to make a reference of our tilt angle.
In order to prove our theories, a prototype team went to work right away building a wooden velocity wheel “rig”. A motor was mounted in a wooden chassis along with the gear tooth sensor. Because of our inexperience with PID control in the Innovation First controller, we had to understand the capabilities of the PIC microcontroller processing power and speed at which it could evaluate the gear tooth sensor to make a good closed-loop system. The first concern was that the gear tooth sensor would be wired and configured into the controller as a hardware interrupt. This sensor would interrupt the normal control loop of the controller thousands of times per second. Our first test comprised of a large tooth gear that would only induce about 200-300 interrupts per second. We found that this affected the resolution of the feedback system and made it very difficult to tune the PID. Low resolution meant our PID system responded “sluggish” no mater how hard we tried to perfect the tuning parameters. Tuning a system means adjusting the PID multipliers commonly known as Kp, Ki and Kd by adding in various amounts of these functions to get the system to behave the way you want. Our tuning method comprised of using National Instruments LabView Dashboard for a real time feedback process to see the response of the output based on our tuning parameters. In order to make quick on-the-fly adjustments, we built a PID tuning board out of three simple potentiometers. Each pot represented each value, Kp, Ki and Kd. The pots were wired to three of the analog ports on the Innovation First controller and software scaling replaced the tuning variables inside the code that was written.
Our final proto-type consisted of a very large gear with fine pitched teeth that induced about 1200-1400 interrupts per second and gave us the best tunablity of our PID system. Once we set a velocity in the software, the gear tooth sensor measured a scaled velocity value as feedback and the PID control kept the ball shooter wheel spinning at the desired velocity. Because our shooter mechanism would shoot 10 balls one right behind the other, this created a drag or velocity recovery on the ball shooter wheel. After each shot the velocity of the wheel would decrease. With the PID control system in place continuously in a closed-loop fashion, after each shot the gear tooth sensor would measure the velocity of the shooting wheel, if the velocity was below the desired set point, the controller would increase the speed of the shooting wheel to keep the ball shooting wheel at the desired speed to make the correct trajectory launch. Of course if the wheel was measured too fast, the controller slowed down the ball shooter wheel to keep the velocity at a maintained velocity.
Now that we had a workable PID system in place, we still need to input our PID system with the “set point” value. The set point was derived using basic trigonometry. The goal light was at a fixed height of approximately 10.5 feet. Because our camera was mounted at a known height, we calculated a distance using trigonometry by knowing the angle the camera is tilted to solve the distance from the light we are located.
The required ball velocity was solved offline using an Excel spreadsheet at certain angles. We called these angles our calibration angles. At each calibration angle we created a lookup table reference that we could code in the Innovation First controller. We then linearly interpolated points between our calibration angles to make up a 75 point or 75 angle lookup table. Each angle was assigned a velocity value depending on the angle of the camera, that velocity pointer was feed into the PID control loop to control the speed of the shooting wheel. This simplified the math the controller was required to execute and streamlined coding efficiency.
Basically the greater the camera tilt angle, the slower the velocity command was, the smaller the tilt angle, the faster the velocity command was, meaning the robot was deeper in the field.
Hope that helps.
ID:	4406  Click image for larger version
Favorite CD quote:
Unread 15-05-2006, 22:16
DonRotolo's Avatar
Back to humble
FRC #0832
We toyed with that, but decided not to waste the CPU time, instead using the A/D values directly. They came out to something like 1/23 of a degree for each count...
Don
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How did you thank your engineers/mentors/sponsors this year? Bharat Nain Thanks and/or Congrats 15 01-08-2004 21:18
will your team use bumpers this year? Alex Cormier General Forum 7 30-01-2004 15:31
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
