Go to Post I don't think Dean Kamen ever recieved a real degree. That doesn't make him any less of an engineer.:) - Adam Y. [more]
Unread 18-05-2006, 16:07
jeffmorris jeffmorris is offline
jeffmorris is on a distinguished road
VEX Shaft Encoder Kit
I got an idea for a X-Y table for routers. If I use 10-32 threaded rods, nuts, and screws, and I wish to have one of the carriages move exactly two inches, how do I program the encoder in Easy C 2.0? Is it possible to control the X-Y table from the computer instead of the R/C transmitter or writing a program to control the X-Y table?
Unread 19-05-2006, 12:23
frodus frodus is offline
frodus is an unknown quantity at this point
Re: VEX Shaft Encoder Kit
As long as its serially controlled. Look at the examples, it sends serially TO the computer, its not much different to RECIEVE from it. YOu just have to send it a position, and the vex will control the x-y.
Should be able to make a program for it too. Check cnczone.com (i think) and see if there's some free programs, then you can see what the comm protocol is and write your software for that. That way it would be fairly easy to do.
FRC easy-c vex encoder function? Gdeaver Programming 2 23-01-2006 08:03
VEX EDUbot hybrid or $50.00 VEX kit? Tazlikesrobots Robot Showcase 15 13-08-2005 22:12
Which shaft encoder to use? Jeff Waegelin Electrical 22 18-06-2005 03:57
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
