Go to Post Remember, just because you saw it on ChiefDelphi, doesn't make it true. - Karthik [more]
Unread 22-05-2006, 21:44
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: Looking for Mecanum Wheels
Heres a picture of the wheels the TechnoKatz had in Atlanta. I personally thought they were a bit bulky, but it was a good prototype. I hope for it to be more streamlined and a bit lighter. Those wheels must have weighted 4-6 pounds each. Well I would really like to give mad props to AndyMark for making a holonomic Drive system compatible with the KOP chassis. Now if you guys made small 14-1 gearboxes for one cim to compliment it, you'd be a FIRST God. O yeh, on a personal note, as much as I love these wheels, I'm going to try to steer my team away from it because I like having a unique design. I like the challenge of building something new, creative, innovative, beautiful, and works really good too and getting the satisfaction of building something that performs amazingly. Well I'm glad you made these mecanums and good luck to the teams who use them. Heres that picture. Sorry I made it a short monolouge there.
http://www.chiefdelphi.com/media/photos/25002
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 22-05-2006, 21:47
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Originally Posted by Andy Baker
We were thinking to have a 1.124" hole in each side plate, for mounting a 1/2" id flange bearing, but if most people want to use 3/8" bearings, we can do a 0.874" hole. Now is the time to give us input on this.
Not knowing your manufacturing process would both be an option? If not my thinking would be to go with the 3/8" setup (0.874" hole) and the user can just bore a larger hole as needed. It is always much more difficult to put metal back in the hole than it is to take it out.
Unread 22-05-2006, 21:56
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Originally Posted by DeepWater
Sorry 'bout that. My bad. Whoever designed them did a great job and I love 'em!
Designer = TechnoKat mentor Mark Koors
This is a good point. We've got some time to make this decision. I also like the 3/8" bearing hole (~0.8745") for mainly this reason.
Andy B.
Unread 22-05-2006, 22:28
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
I think you should bore them to 1.124 and also make pressfit bushings available to easily convert them the .874 if needed.
In actuallity though you can buy bearings from mcmaster that are 3/8 and have an OD of 1.125.
edit: although andy are the holes on the hole pattern going to be #10 (like ifi sprockets and the deka plastic hubs or are they going to be 1/4 like your molded omni wheels?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 22-05-2006, 22:39
Rookie Year: 1998
Ugh... thanks for reminding me of that mistake.
These holes will be #10 clearance holes (or M5), at 0.205-0.210 diameter.
The 0.250" holes in the omni-wheels were designed to be #10 clearance holes also, but our molder turned them into 0.250".
Andy B.
Unread 22-05-2006, 22:44
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
I'll second (or vote for) that. Let the standard wheel be a fit for the standard hub.
Ask and ye shall receive. Such a hub is already available.
If we go with 1.124" holes for 1/2" flanged bearings, that Universal Hub fits right in the hole and mates up with the 1.875" hole pattern.
Thanks,
AB
Richard Wallace
since 2003
Unread 24-05-2006, 12:54
Another option might be to make them 1.124 for the 1/2" ID flanged bearings and if someone wanted to use a 3/8" shaft just put a 3/8" ID / 1/2" OD flanged bronze bushing in the 1/2" ID roller bearing to take up the space. They are cheap (~$.50-$.75) and readily available from places like McMaster and MSC.
Unread 22-05-2006, 20:56
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Team Role: Teacher
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Andy,
I got to see the new AndyMark Mecanum wheels in Atlanta and I love the simple elegant design. I was really bummed when I didn't win them! There was mention of a possible white paper on them to be posted on the TechnoKats website. Is this still fourth coming? How about posting a picture so that everyone that didn't get to see this much sought after COTS product can see what they have to look forward to. I predict many teams will have Mecanums this next year! Great job bringing these sort of products to the market for teams that don't have the resources to make them themselves. Kudos to you and Mark!
BTW: What sort of hub setup are you thinking of for the final design? For what it's worth I would love to see a setup compatable with IFI wheels with the same sort of 3/8" flanged bearings and sprocket hole pattern (6 on 1.875" IIRC). They would then be a drop in replacement on the KitBot chassis.
The mecanum wheels in Atlanta were not Andymark wheels, they were the TechnoKats. Some of you asked me if they would be Andymark products, now you know!
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 22-05-2006, 21:40
Unread 22-05-2006, 12:21
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Any more details? Wheel width, number of rollers, roller diameter & length (material?), and overall weight. All this would be helpful in thinking of a robot design that uses these wheels.
Could you attach a image of the mechanum wheels for those of us that were not there to see them? This would be nice.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 22-05-2006, 17:05
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
AndyMark will be selling 8" Mecanum wheels this fall. The design is based on sheet metal sides with bent tabs. These wheels were seen at team 45's pit at the Championships. The unofficial price target for each wheel will be between $75-$90. They will be available in the early fall (end of August).
PM me if you would like more information on these wheels.
Andy B.
And here we have another miracle to attribute to St. Baker of the Gears. Now, if only they could make all-in-one packages for DeWalt transmission conversion to the CIM motor to use with these forthcoming Mecanum wheels.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 22-05-2006, 17:51
Rookie Year: 1996
An awesome array of traction system components are offered by this supplier.
It will be very interesting to see how many 'bots are sporting "Powered by AndyMark" stickers on their chassis next year.
Richard Wallace
since 2003
Mechanum Wheels Andy B Technical Discussion 2 10-01-2006 17:41
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
[OCCRA]: Looking for SPECIFIC Dimensions for the Game field! stk86 OCCRA Q&A 1 28-09-2004 10:46
i'm looking for a contact for team 1059 and 546 Mike Persico Scouting 1 20-01-2004 21:01
Looking for sponsors for New Team in the Berkshires Gabriel Fundraising 1 30-10-2003 13:07
