Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Unread 22-05-2006, 16:35
silv940's Avatar
silv940 silv940 is offline
AKA: Sam Wilkins
FRC #1572 (Hammer Heads)
silv940 is an unknown quantity at this point
Send a message via AIM to silv940 Send a message via Yahoo to silv940
Question Momentary Switch Programming
I need help on the programming of a momentary switch used for a double solenoid. I basically want the solenoid to fire when i press the button then when I let go it should retract. I have the switch wired to p1_sw_trig on the OI. The solenoid is wired to relay two. The two grounds from the solenoid are wired directly to the battery ground. One red switch is wired to M+ and vice versa. Thanks
Unread 22-05-2006, 17:12
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Momentary Switch Programming
Are you saying that the black wires from the solenoid are connected to the ground, and one each of the red wires are connected to M+ and M-? If so, that's not the FIRST-legal way to wire a double solenoid - you're supposed to use either two Spikes, or a couple of diodes in to connect all 4 wires to a single Spike.
Nevertheless, if you do something like this, it should work:
Code:
relay2_fwd = p1_sw_trig;
relay2_rev = !p1_sw_trig;
or if that turns out to be the opposite of what you want, try
Code:
relay2_fwd = !p1_sw_trig;
relay2_rev = p1_sw_trig;
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 22-05-2006, 17:57
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
WE have wired the solenoids this way in the past and posted a question on the Q & A forum. First approved it in 2004.
Unread 24-05-2006, 02:19
silv940's Avatar
AKA: Sam Wilkins
Thanks alot.
problems programming knob and switch caderader Programming 4 16-02-2006 16:45
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
Problems programming a switch caderader Programming 2 18-02-2005 22:06
3 way toggle switch programming LeadRiccardoT Programming 3 17-02-2003 02:02
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
